Service manual available yet ?
Results 1 to 2 of 2
Cadillac STS Forum - 2005 through 2012 Discussion, Service manual available yet ? in Past Cadillac Vehicle Discussion; I was hoping I could locate the ground wire that disable nearly every useful on screen function when the car ...
    Spectre's Avatar
    Spectre is offline Cadillac Owners Member
    May 2004
    41
    I was hoping I could locate the ground wire that disable nearly every useful on screen function when the car is not in park . I suppose that cadillac assumes you won't have passengers working the nav huh ?
    Dualcams34 is offline Cadillac Owners Member
    Feb 2005
    60
    Re: Service manual available yet ?
    Hi,
    Unfortunately, you must be a computer programer to bypass the "in gear" feature for this radio. All the data is communicated via a on board LAN. If you try to compromise this system you may create different problems. There is nothing you can do at this time to disable this safety feature.
