Not a Map DVD
Results 1 to 4 of 4
Cadillac STS Forum - 2005 through 2012 Discussion, Not a Map DVD in Past Cadillac Vehicle Discussion; Every once in a while (probable a dozen times) when I turn on the Nav system I get a message ...
    Adrian XIII's Avatar
    Adrian XIII is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Mar 2005
    Wateford, CT
    75
    18
    QuestionNot a Map DVD
    Every once in a while (probable a dozen times) when I turn on the Nav system I get a message that says something like "Not a Map DVD. Insert a Map DVD and try again."
    Ejecting and reinserting the DVD does not help. Sometimes turning the engine off and restarting clears the problem.
    Anyone else have this problem?
    Kitty's owner is offline Cadillac Owners Member
    Mar 2005
    Bend, OR
    4
    Re: Not a Map DVD
    I have had my new STS since 3/3/05 and I have had this problem twice. Turning off and restarting the car fixes the problem. Now I just make sure the map is working before I take the car out of park.
    LetsDance is offline Cadillac Owners Member
    Feb 2005
    45
    Re: Not a Map DVD
    I also had this problem, mine only occured with the driver 2 fob. I took the car back to the dealer and they fixed the problem, they fixed it but didn't tell me what the problem was.
    zwhiteknight is offline Cadillac Owners Member
    Mar 2005
    1
    Re: Not a Map DVD
    Hello there, I had the same problem with mine and it ended up being that I had a bad Map DVD. It took 3 Map DVDs before they gave me a good one. Hope this helps you out.
    Ricky
  7. Remove Advertisements
