Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: 2007 STS Shift to park error!!!
    Feb 2005
    21
    Hello, does anyone know how to remove the console on a 2007 STS?? I will need to remove it to replace the shifter assy. My STS has only 50k on it. Any way the error will not go out now and runs the battery down. Thanks Paul
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: 2007 STS Shift to park error!!!
    I think some members have found success with adjusting the shifter but my wife's dealer replaced hers. I trust a member who's done the job will chime in soon.
    For a while, pressing the brake and/or fiddling with the shifter helped shut off the car. But then the lights started staying on and/or it kept running; a real pain. Her extended warranty covered all but a deductable. These are not inexpensive cars to enjoy, but we sure did today! 4 states worth (I-70 -> I-75 -> US-35 -> I-64 -> I-77 -> I-64). I-81 is next! (Please forgive the thread Hi-jack!)
    Good Luck!
    Feb 2005
    21
    Thanks, I have a new shifter assy. but was needing help on how to remove the console.
  5. #4
    Carvone is offline Cadillac Owners Fanatic
    Automobile(s): 07 STS 1SG / 10 STS 1SG / 17 XTS
    Nov 2008
    Florida
    55
    274
    I had the same message on mine, while it was in for warranty work I asked them to look at it. It is a non-warranted item and it would cost and hours labor, so I went home a tried it myself. Put the car up on the ramps, slide under the passenger side at the shifter area. You will see the shifter lever and adjustment bolt right there (I think it was an 8 or 9mm), loosen it, move it a half inch, and retighten. Get in car and test, most likely you went the wrong way, so go back under and move and inch in the other direction and try again. It took me a couple tries to find the sweet spot but it is perfect now.
    Super easy job that takes all of 10 minutes. I would try this first before installing a whole new shifter assy.
  6. #5
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,549
    From this thread I posted on this subject.
    Quote Originally Posted by Ludacrisvp View Post
    Automatic Transmission Shift Linkage Adjustment
    (Note: this was posted online in 2008 so it likely applies to model years newer than this as well, I have not seen this in any TSB)
    Hope it helps someone that is having issues with their shifter, maybe it will be good info.
    This information applies to the 2004-08 SRX, 2005-08 STS and 2006-08 CTS equipped with automatic transmissions.
    Many automatic transmission shift control related concerns can be corrected with linkage adjustment.
    DO NOT replace a shifter assembly without first attempting to correct the condition with the linkage adjustment procedure (fig. 8).
    Refer to SI for the proper service procedures.
    A Adjustment issues - forward biased
    B Adjustment issues - rearward biased
    TIP: Symptoms of forward-biased adjustments (fig. 9) include cluster blanking out in Drive, and Tap Mode not functioning.
    Ensure that the linkage is adjusted properly when Drive blanks out, or Tap Mode does not function.
    A Forward biased
    C J-bracket
    D Linkage
    TIP: Symptoms of reverse-biased adjustments (fig. 10) include the inability to remove the key, or inability to exit Accessory Mode.
    Ensure that the linkage is adjusted properly when there is the inability to remove the key, or inability to exit Accessory Mode.
    B Rearward biased
    C J-bracket
    D Linkage
    TIP: When diagnosing a binding shift control system, disconnect the linkage from the shifter assembly and check the shifter assembly
    for smooth operation independently from the linkage. The transmission should be in Park during evaluation.
    The linkage adjustment procedure is critical for proper transmission operation; therefore, several checks need to be performed after
    the linkage is adjusted:
    - Inspect the operation of the starting system with the shift lever in each position.
    -- The engine should crank only when the lever is in the Park or Neutral position.
    - Ensure that the feel of the shift detents align with the gear indicator.
    - When in each gear, apply the button and release. Then slightly reposition the handle fore-and-aft in the vehicle. The button pawl
    will make a clicking noise if it is caught on a control mechanism gate. The button should not get caught up on the control mechanism
    gate in any gear. Readjust and retest if necessary.
    - Return the lever to the Park position and check for proper engagement. Park position should feel solid and not spongy.
    The shift lever should not be bottomed out on the stop bumper when engaging the Park position. Readjust and retest if necessary.
    - With the ignition on and the engine not running, ensure a smooth transition from position D to Tap Mode and back.
    Ensure that the DIC changes to the gear indicator mode. If the DIC does not change to gear indicator mode, or any binding or rough
    spots are felt, repeat the linkage adjustment procedure and retest the system.
    If any of the following conditions exist after performing the linkage adjustment, the shifter may need to be replaced.
    - The shifter binds when putting the vehicle into gear or Park
    - The ignition key sticks or is hard to remove from the ignition lock cylinder (SRX only)
    - The Shift to Park message is constantly displayed on the DIC when the shifter is in the Park position
    - Dead battery
    - The Tap Shift functions may experience a delay when operating the Tap-Up or Tap-Down mode
    - The Tap Shift functions are inoperative
    - The MIL/SES light is illuminated with one of the following DTCs:
    - DTC P0815 - Upshift Switch Circuit
    - DTC P0816 - Downshift Switch Circuit
    - DTC P0826 - Up and Down Shift Switch Circuit
    - DTC P1876 - Up and Down Shift Enable Switch Circuit Low Voltage
    Source
  7. #6
    PzNuts is offline Cadillac Owners Member
    Automobile(s): STS
    Jan 2012
    33
    Can't help with a how-to but I find it interesting that I have the same year STS and mine crapped out at 55k mi. Extended warranty took care of it, but still, wtf?
  8. #7
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Dealers would rather replace than adjust and take the chance of a second visit. Even without warranty, it's still not much, under $500.
    What do think you bought?
  9. #8
    tomlittle1 is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac STS
    May 2014
    63
    Would love to see pictures, I could not see the shifter linkage from beneath my 2007 STS4???????????????????????????
  10. #9
    Feb 2004
    1
    My 2008 STS started with the same "error code" again. Dealer replaced complete unit 6+/- months out of warrantee at $700+ charge. I questeioned if there was a solution then. Hope there is now. 87k now. 60k then.
  11. #10
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,549
    Quote Originally Posted by oatzen View Post
    There is a thread on here about replacing the microswitches in the assembly for much cheaper than a new shifter assembly if you are mechanically inclined which has been reported to resolve this issue if your issue wasn't caused by a faulty alignment.
  12. #11
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    I had this error once but mines had nothing to do with the shifter. Mines was a sensor error in the transmission. I can't remember the name of the part but it tells the car what gear the transmission is in. It happened while I was driving, I felt a thud then the d for drive in the dic went away and the car was stuck in third gear. I got the car home shut it off and it said shift to park. I restarted it and the gears shifted fine but still had the shift to park error. So I just disconnected the battery touched the cables together and crossed my fingers. Put it together and it works fine. Knock on wood. I've it a try.
  13. #12
    ddalder's Avatar
    ddalder is online now Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,851
    The shifter seems to be the most common fault, although I'm sure there are other causes. The thread on how to adjust or replace the microswitches in the shifter seems very helpful.
  14. #13
    sandmanlapaz is offline Cadillac Owners Member
    Automobile(s): 2007 STS 4 AWD
    Dec 2013
    Mexico
    63
    3
    I just adjusted mine on a 2007 STS but it did not cure the problem. The cable is on the DRIVERS SIDE not passenger. 10 mm not 8 or 9. New shifter assembly next,
  15. #14
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,549
    Quote Originally Posted by sandmanlapaz View Post
    Sounds like you may have failed micro switches in the assembly. There is a thread here on how to replace them.
  16. #15
    hiltonny is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Apr 2008
    172
    Search the archives for the console removal directions, they are in there. Here's a link for adjusting the internal switch when you have the shifter out, http://www.cadillacforums.com/forums...ifter-not.html.
  • You may not post replies
