CTS-V brakes on an STS
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By 1BadCadSTS
Cadillac STS Forum - 2005 through 2012 Discussion, CTS-V brakes on an STS in Past Cadillac Vehicle Discussion; I'm just curious would it be possible to swap the brakes on my RWD 2008 STS for the brakes on ...
    studio caddi is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS 4.6 Northstar
    Dec 2011
    139
    I'm just curious would it be possible to swap the brakes on my RWD 2008 STS for the brakes on a CTS-V and would they make a big improvement in braking performance ? Also what would be required to make this swap .
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    18" wheels with 40mm offset
    rotors
    V calipers
    That's how I got them to work on the front. Forget the rears they are just eye candy.
    Search I've done a post on it. I'm the only one who has done it to my knowledge.
    Charles Warren's Avatar
    Charles Warren is offline Cadillac Owners Fanatic
    Automobile(s): 2008 sts-v black raven 2004 cts black raven
    Nov 2011
    Atlanta, Georgia, United State
    88
    459
    Re: CTS-V brakes on an STS
    so no hub change???
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Not with correct 14" 5x115 rotors.
    Nov 2011
    88
    459
    oh gotcha like shelby mustang
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Correct. They are 5x114.3 but the tolerances are enough they clear and work perfectly.
    Charles Warren likes this.
    Nov 2011
    88
    459
    now i gotta spend more money thanks to you lol.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Not that expensive hahaha. Honestly if you check eBay or amazon oe wheels is selling a v knock off 5x115 with a 40mm offset to clear. That's my next expense so I can reinstall my brembos. I tanked my custom rotors and wasn't going to pony up 500 for another set nor do I trust wheel spacers. I have 250 in the calipers and it will be just around 600 for wheels so for under a grand I have a big brake set up that parts can be bought at any auto store to service as opposed to having to order from Baer or Willwood.
    Nov 2011
    88
    459
    i need rotors anyway so id rather buy those instead of stockers. does the v brackets bolt right up???
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Brembos are not a floating caliper like the current jl9 or je5 setup. The caliper has the mount attached and does not move. To answer your question though the v spindal is the exact same spinal as ours so it bolts right up. The mustang rotor does require a thick washer between the spinal and caliper ears or it will rub the rotor.
    scott9001 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 sts N* 1965 coupe deville
    Aug 2011
    26
    364
    What did you do for a flex hose factory sts one or what?
  14. Remove Advertisements
