Transmission/Engine Question.
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Cadillac STS Forum - 2005 through 2012 Discussion, Transmission/Engine Question. in Past Cadillac Vehicle Discussion; I have a 2006 Cadillac STS V8 N* now when im at high way speeds should my engine be running ...
    Jneedom14 is offline Cadillac Owners Member
    Automobile(s): STS
    Mar 2013
    41
    42
    I have a 2006 Cadillac STS V8 N* now when im at high way speeds should my engine be running at about 2k RPM keep in mind im running lean so would that have anything to do with it and could it be the transmission not shifting into the appropriate gear that could cause the high rmp at highway speeds.
    curtc's Avatar
    curtc is online now Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    That's about what mine runs at 70mph...
    Automobile(s): STS
    Mar 2013
    41
    42
    Re: Transmission/Engine Question.
    Okay i just thought it was a little weird for it to be like that....And my intake manifold bolts are good so it must be something else causing me to run lean
    and what kind of transmission is in our cars
    mckellyb is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS N*, 1SF, 144K mi.
    Apr 2011
    Fort Worth
    650
    5L50E, it was a joint design with BMW...turns out diesel Range Rovers use the 5L40E, and the 50 is a beefed up version of the 40E.
    You think it revs high, now, huh? The 4th-5th solenoid in my transmission finally died, and 4th gear, while peppy, makes for about 2,800 RPM @ 65.
    It is quite responsive, however.
    Automobile(s): STS
    Mar 2013
    41
    42
    How much to replace that solenoid.
    Apr 2011
    Fort Worth
    650
    The part is about $25. I'm going to do all four solenoids, three shift solenoids and the torque converter one, a filter, and rubber gasket for about $150, shipped. All shipped Priority Mail, 'cause I want to fix it this weekend.
    To have it done, I have no idea, as you have to pull the pan and the valve body. I may use this to put a final six quarts of fresh Dexron VI into it, too, and that's an extra $37, or so, from Amazon (with Prime, so no shipping...it's like cheating, but I Amazon enough for it to more than pay for itself).
    Automobile(s): STS
    Mar 2013
    41
    42
    Okay my engine is at 2K at like 80-85 so i guess its normal. And i cant diagnose my lean condition.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Take it to a dealer and be done with your problem.
    Charles Warren's Avatar
    Charles Warren is offline Cadillac Owners Fanatic
    Automobile(s): 2008 sts-v black raven 2004 cts black raven
    Nov 2011
    Atlanta, Georgia, United State
    88
    465
    2000k at 75 mph sounds normal and mount could be broke who knows, more info would be needed to tell you whats wrong
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Don't forget there's 3 different axle options which will determine cruising speed. 2.73 3.23 and 3.42
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,550
    I wish I could be at 2k RPM going 80-85MPH, I'm like 1800/1900 RPM at 65MPH and probably about 2400? at 80MPH. I'd have to go for a drive to find out again for sure though.
    Mine is GU5 (3.23:1) which I understand to be the only option for the AWD model.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by Ludacrisvp
    Correct. Unless you swap to srx v6 diffs. Those had 373s. Of course that will net worse mpg over the 323.
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,550
    Quote Originally Posted by 1BadCadSTS View Post
    Which I assume was done to improve the acceleration characteristics of the V6 model?
    I have to wonder if one could swap out to using the LSD 2.73 diffs in lieu of the current 3? open diffs in the STS4
  16. #14
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    You could but you would need a tune for it and would have to do both front and rear diffs.
    Correct the v6 was given the 373 to help acceleration. I believe the also had 390s but I'm not sure. I just know my sisters 05 awd v6 sport has 373s.
  17. #15
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    All the AWD's (V6 & V8) had 3.23 final gears, right? I know fleet & rental V8's in 2007 came with 2.73. 3.42 was the hottest final gearing and I thought it was standard on the RWD 1SG & optional on the 1SF. Although I don't know why, I had the idea that all the early (non-DI) V6's were 3.23. I'm sure some gear would have helped it off the line. Even later V6's were at a major disadvantage in torque, which is a better indicator of performance in a 2-ton touring sedan.
    My 2006 V8 AWD 5-speed turns 2K RPM doing 60MPH on 235/50R18's (virtually the same circumfrance as the OEM 255/45R18 rears.) To the extent I'm right, all AWD's would do so as well; maybe the early V6 RWD's, too. My wife's 2007 V8 RWD 6-speed has the 2.73 and 2K RPM has us cruising at 80 MPH on the stock wheels & Summer Conti DW 235/50R17 tires.
  18. Remove Advertisements
