2005 STS with Nav Ipod interface help???
Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Like Tree2Likes
Cadillac STS Forum - 2005 through 2012 Discussion, 2005 STS with Nav Ipod interface help??? in Past Cadillac Vehicle Discussion; Alright guys i have 05 STS with nav... im looking for a ipod soution beside using the RCA Jack. I ...
    jhj4519 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac STS
    Jun 2009
    10
    Question2005 STS with Nav Ipod interface help???
    Alright guys i have 05 STS with nav... im looking for a ipod soution beside using the RCA Jack. I would be nice if i could use the touch screen or the radio controls.. I been looking around and iSimple GateWay has this ISGM574 interface for calillac sts 06-2011. Im not understanding why this will not work on my 2005 since the nav radio in the 2005-2007 are the same. Not even sure if its meant for the nav radios. Anyone tried to use the isimple??? or have any other ipod solutions??
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Works fine on my 05 sts with nav.
    Jun 2009
    10
    Re: 2005 Cadillac STS with Nav Ipod interface help???
    I thought it should work but i wasnt sure... Thanks for the reply.
    Has any installed the isimple ipod interface and a lockpick?? is it even possible??
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Yup. I have both. You'll need a modified lock pick to work on an 05 and they are no longer made. Unless you have one your sol.
    Jun 2009
    10
    yeah i was asking because i already have one.. Not a lot of room behind the nav radio to work with. if u got any cable management suggestion i would appreciate it. Otherwise thank for the help!
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Tie a string to the wire around back and pull it while feeding the radio in.
    Not easy by any means. I have an hdrt and a blustar back there too. I switch between the two every so often.
    Jun 2009
    10
    ok i will give that a try. I will post back when i install the interface. Thanks again!
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,548
    1badcadsts - thoughts on the HD radio?
    worth it?
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    For hockey season it is. A few other stations I listen to on occasion. If you pay retail I don't think so. If you wanna buy mine id sell it haha.
    Guy.Seminerio likes this.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I added the HD when I did mine. I never use it. DO NOT SPLICE/SPLIT ANTENNA WIRE/CONNECTORS. You'll lose too much signal and regret it. If you go this route, add another antenna. I use a little aux job I had laying around from an old analog cell phone. It works just fine in the glove box.
    I too, use a string to get all the connectors & cables back where they need to be. The GPS wire is short and makes it a tricky job.
    The 2005-7 Nav is not identical, but often compatible.
    Jun 2009
    10
    so what the difference between the 2005 nav and the 2006,2007? is it software or different specs???
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Different security checks to lock out the nav.
    Jun 2009
    10
    Quote Originally Posted by 1BadCadSTS View Post
    So could u buy a used 2007 nav and put it in a 2005?
  16. #14
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I meant the 2005-2007 Nav is different than the the later ones. Maybe there are other variations. Check part numbers to be sure.
    Members report success with some unmatched swaps but there is some risk involved.
    The firmware upgrade for the early years is very worthwhile and required to use the newest map disks.
  17. #15
    Jun 2009
    10
    (The firmware upgrade for the early years is very worthwhile and required to use the newest map disks.) What do u mean by that? Are u saying that the 2007 firmware is better??? Do the later unit repond faster?
  18. Remove Advertisements
