05 STS V8 4 transmission fluid
Results 1 to 10 of 10
Cadillac STS Forum - 2005 through 2012 Discussion, 05 STS V8 4 transmission fluid in Past Cadillac Vehicle Discussion; I was looking for my transmission stick and couldn't find it. I checked the manual and it said to have ...
    STSJr's Avatar
    STSJr is offline Cadillac Owners Fanatic
    Jul 2013
    145
    I was looking for my transmission stick and couldn't find it. I checked the manual and it said to have the dealer check it. I like to check my own fluids. Can someone tell me how to check my transmission fluid. Thank you!
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Take to dealer.
    Sealed non serviceable unit.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,046
    Re: 05 STS V8 4 transmission fluid
    Sucks but it is what it is....
    STSJr's Avatar
    Jul 2013
    145
    Wow! Interesting. Thank you again!
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,242
    The fluid level of the transmission can be checked by having the car up on jack stands, level, and engine running by removing the fill plug. Don't turn off the engine with the plug out or it's oil everywhere. A GM study convinced them that a major cause of transmission trouble is dirt and other inappropriate material introduced by DIY maintenance efforts. The transmission is assembled in a clean room and sealed at the factory.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Unfortunately, Koz forgot to mention the word 'hot' and that the filler plug isn't an easy task. IMHO, leave it be unless there's a concern or you want to change fluid. If that's the case, it's time to decide whether to go with the traditional pan-drop/gasket/cleaner change or a flush. Both have their adherents.
    I'm now in the former camp.
    mckellyb is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS N*, 1SF, 144K mi.
    Apr 2011
    Fort Worth
    650
    I've changed mine, recently, and it was not the slightest bit pleasant. Still have a burn on my left forearm from it, in fact.
    I need to change it one more time, but I have a Futomo valve I'm going to put in the pan, so I can drain it, measure, then put back what I took out. That's easy enough.
    The placement of the fill port is situated such that it must have been made intentionally difficult to access.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,242
    I've resisted all temptation to fool with mine and so far it's working great. I'll give you another report in about five more years. When I was much younger I disassembled just about every mechanical thing I had just as soon as I purchased it to see what was inside. Now that I'm much older and wiser I can see that it was not always the smart thing to do.
    STSJr's Avatar
    Jul 2013
    145
    Wow! Thank you again.
    KRSTS Guest
    Quote Originally Posted by dkozloski View Post
    I'm with you KOZ and almost as old. I now am now a firm believer in "if it ain't broke, don't try to fix it."
  13. Remove Advertisements
