Power steering
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By STSJr
Cadillac STS Forum - 2005 through 2012 Discussion, Power steering in Past Cadillac Vehicle Discussion; Hey having some issues with my 05 v8 no power steering at idle rev it up a bit to move ...
    scott9001 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 sts N* 1965 coupe deville
    Aug 2011
    26
    364
    Power steering
    Hey having some issues with my 05 v8 no power steering at idle rev it up a bit to move and it's back I think it needs a pump but I have to get some readings to see pressure out of the pump. I haven't been under the car to check but do they have magnasteer my 97 deville did. Anyone have this problem?
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Power steering
    PS Pump issues aren't uncommon. One of the pump fittings has been called every name in the book and is still fighting. If you DIY, beware!
    STSJr's Avatar
    STSJr is offline Cadillac Owners Fanatic
    Jul 2013
    145
    I have an STS V8 4 and the steering is a little harder at low idle but its a four wheel drive car. No noise and fluid is full. Hope I was helpful!
    Guy.Seminerio likes this.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Power steering
    I don't notice much as the assist varies. I do try to be easy on equipment and generally begin rolling (even if slowly) prior to turning the wheel. My earliest cars did not have power steering and that teaches good driving habits, IMHO.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    Re: Power steering
    If the car steers hard at an idle the PS pump is shot and will get worse. Wait until you go to turn into a parking slot and the car goes straight. You'll find out.
    Don't mess with Binky Bear!
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Power steering
    The variable assist should lessen as speed increases. This isn't new technology. My '88 Impulse had it. So did my '93 Roadmaster.
    Aug 2011
    26
    364
    Re: Power steering
    I put a pump on the other night after work! Everything good so far only has 200 psi at idle on the old pump I never did check the new one after tho and had one hell of a time getting fittings on the pump to take a reading but overall nice easy job
  10. Remove Advertisements
