CEL still running lean
Results 1 to 8 of 8
Like Tree2Likes
  • 2 Post By dkozloski
Cadillac STS Forum - 2005 through 2012 Discussion, CEL still running lean in Past Cadillac Vehicle Discussion; Please help me i have a 2006 Cadillac STS V8 and im trying to figure out why its running lean ...
    Jneedom14 is offline Cadillac Owners Member
    Automobile(s): STS
    Mar 2013
    41
    42
    Please help me i have a 2006 Cadillac STS V8 and im trying to figure out why its running lean its good when i get into the throttle but at idle it is a little shaky not misfiring just stumbling a little. And what all can happen from running lean i dont want to damage the engine.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,171
    Re: CEL still running lean
    Check the intake manifold bolts. It's a very common problem.
    Don't mess with Binky Bear!
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Deja Vu
    Hey -14. Why not just post that your bolts are tight, even if you never checked them? I'm tired of this nonsense!
    Lean engines will run hot and in extreme cases burn valves & pistons.
    It's quite simple, when a Check engine Soon light comes on, have the car serviced. If it flashes, do so immediately. Although Cadillac dealers aren't inexpensive, they can actually provide the best value by not doing (and charging you for) unecessary repairs.
    Many free parts store code readings will only provide the basics on the STS. These are sophisticated cars and the finer details often require more.
  5. #4
    glover is offline Cadillac Owners Member
    Feb 2012
    26
    Definately ck intake bolts Prolly needs a new booster hose they swell at the back of the intake. Ck ur air filter if it hasnt been replaced lately n depending on last time u went to a dealer might need a reflash. Otherwise, inspect for any loose hoses n the pcv system
  6. #5
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,028
    Quote Originally Posted by Jneedom14
    You have another thread going about this already...why two?
    HAVE YOU CHECKED THE INTAKE MANIFOLD BOLTS????
    AGAIN, HAVE YOU CHECKED THE INTAKE MANIFOLD BOLTS????
  7. #6
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Ignorance is bliss
    Stupid is as stupid does
    You can lead a horse to water but you can't make him drink
    Anyone else?
  8. #7
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,171
    Quote Originally Posted by 1BadCadSTS View Post
    Ignorance is bliss
    Anyone else?
    You can lead a horse to water but you can't make him drink but three Texans can. Two to hold his head under water and the third to suck on his a$$.
    curtc and MoistCabbage like this.
  9. #8
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    That horse is gonna drown.
  10. Remove Advertisements
