water in rear floor and dripping from door when its open?
Results 1 to 6 of 6
Cadillac STS Forum - 2005 through 2012 Discussion, water in rear floor and dripping from door when its open? in Past Cadillac Vehicle Discussion; wth.....every time it rains my back passenger rear floor board is flooded and when i open the door water drips ...
    silver02ta is offline Cadillac Owners Member
    Automobile(s): 2005 STS V8
    Nov 2011
    36
    47
    wth.....every time it rains my back passenger rear floor board is flooded and when i open the door water drips out of bottom of door?? I thought it was a bad door seal but why does it get IN the door?
    Alden's Daddy is offline Cadillac Owners Member
    Automobile(s): 2007 STS4 V8 1SG
    Jul 2013
    Salisbury MD
    37
    I had this problem on a different car. Popped out the door seal and found drain hole in the bottom of the door clogged.
    Nov 2011
    36
    47
    Re: water in rear floor and dripping from door when its open?
    ill have to look for a drain plug....
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,827
    This inside of the door is designed to be a "wet cavity" so water getting into the door is quite normal. I've had this problem with many vehicles. If you remove the interior door panel you should find a plastic "water deflector" panel that is supposed to be sealed to the sheet metal of the door. Sometimes these come away from the door and water will end up leaking into the interior of the car. I haven't done a write-up specifically for the STS, but I did for my Bonneville. The principle however is the same. Here's the link...
    http://www.pontiacbonnevilleclub.com...opic11470.html
    This may or may not be your problem, but it's worth a look because it does seem to be fairly common in GM cars. As already mentioned, be sure your drains are free of debris.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Does your car have a sunroof?
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    ^^^ There's a pair of drains that run out via the back deck/trunk space. If one of these were clogged, I could envision water ending up on the back floor.
  9. Remove Advertisements
