External Trans Cooler lines
Results 1 to 4 of 4
Cadillac STS Forum - 2005 through 2012 Discussion, External Trans Cooler lines in Past Cadillac Vehicle Discussion; Does anybody have any pics of the lines or what they did to hook up the lines on an external ...
    Four Fins's Avatar
    Four Fins is offline Cadillac Owners Member
    Automobile(s): 61 Sedan, 06 STS
    Jul 2012
    35
    40
    Does anybody have any pics of the lines or what they did to hook up the lines on an external trans cooler? I'm just thinking, should I cut the metal line at the end of the hose coming from the trans that goes into the radiator and flare them or should I cut it at the rubber hose and just use a double barbed fitting to connect two lines together. The B&M SuperCooler that I bought just uses rubber hoses and clamps. Any help would be great.
    mckellyb is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS N*, 1SF, 144K mi.
    Apr 2011
    Fort Worth
    650
    Re: External Trans Cooler lines
    Well, I can say, when I closely examined the trans cooler lines this weekend, I found the nut and the line are one piece, so you cannot unscrew them like you could for the past 60 years.
    I'm leaning toward the cut and flare, as taking the radiator heater out of the loop can't hurt. I'm considering this, myself, though I wish the 2005 had a monitor for the transmission's temp.
    Four Fins's Avatar
    Jul 2012
    35
    40
    That seems easiest to me as well, just wondered what others did.
    Apr 2011
    Fort Worth
    650
    I'd wager 99.8% have not even remotely considered it.
  7. Remove Advertisements
