Results 1 to 7 of 7
Thread: caliper
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    caliper
    Why is it that my front right caliper is blowing of a lot a of dust compared to the right side and after a short drive when I pour water on it, it sizzles and the passenger side doesn't. Could the caliper be stuck. I just changed the pads pushed the caliper in and the same results.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Definitely sounds to me like your caliper is sticking.
    ITSQUIK's Avatar
    ITSQUIK is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS
    Jul 2010
    314
    I made the mistake of Flip-Flopping the slide pins (top & bottom) when I did my brakes a while back. It caused the calipers to stick & burned up my pads which of course will cause a ton of dust from pads that should virtually be dust free!!
  5. #4
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: caliper
    Tire pressure running high on it after a drive as well?
    These are classic symptoms.
  6. #5
    B1n2fra's Avatar
    Nov 2011
    Chicago
    36
    502
    Found the problem. Not the caliper at all. The top sliding pin is frozen stuck. Does anyone know where I could get a new caliper holder or abutment piece with New slider pins. If that's the name for it. Any where besides the dealer
  7. #6
    surgeont is offline Cadillac Owners Member
    Apr 2013
    Hobe Sound Florida
    64
    9
    Quote Originally Posted by B1n2fra
    Rock auto.com
  8. #7
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: caliper
    It might be worth your time to check with Chris Heath @ Rippy's just to see what he could do for you. Sometimes there are differences in parts and only tires are more important than brakes.
  • You may not post replies
