Resetting oil life on 05 sts v6 transmission
Results 1 to 13 of 13
Cadillac STS Forum - 2005 through 2012 Discussion, Resetting oil life on 05 sts v6 transmission in Past Cadillac Vehicle Discussion; I was wondering how you reset transmission oil life on 2005 Cadillac sts v6, it makes my engine light turn ...
    3.6sts is offline Cadillac Owners Member
    Nov 2012
    9
    I was wondering how you reset transmission oil life on 2005 Cadillac sts v6, it makes my engine light turn on and I already changed it.
    btlegacy is offline Cadillac Owners Member
    Automobile(s): 2005 STS V6 RWD
    Mar 2013
    NC
    31
    70
    Re: Resetting oil life on 05 sts v6 transmission
    After the oil has been changed, the CHANGE ENGINE OIL SOON message must be reset. To reset the message use the following procedure:
    1. Press the up or down arrow to scroll the DIC to show OIL LIFE.
    2. Once the XXX% ENGINE OIL LIFE menu item is highlighted, press and hold the RESET button until the percentage shows 100%.
    If the percentage does not return to 100% or if the CHANGE ENGINE OIL SOON message comes back on when you start your vehicle, the engine oil life system has not reset. Repeat the procedure.
    mjcaddy's Avatar
    mjcaddy is offline Cadillac Owners Fanatic
    Automobile(s): 09 1SG STS4 & Subie CrossTrek (retired 03 DeVille & 05 V6 SRX4)
    Oct 2010
    Chicagoland
    32
    421
    ^I think he was talking about the transmission not the engine, in that case, if your car have it, just follow the same procedure above.
    ddalder's Avatar
    ddalder is online now Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,800
    As I recall, the ability to reset transmission oil life is not possible by the vehicle operator. What makes you believe that the transmission oil life is causing the MIL? Is there some message that appears on the DIC suggesting this is the cause of the fault?
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,215
    My '06 STS doesn't have a transmission OLM, only engine. My '04 CTS had a transmission OLM.
    Don't mess with Binky Bear!
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,956
    Do any of the STSs have that? First I've heard if it.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    http://www.vadengmpp.com/owners-manu...TS.pdf#page258
    Page 261. Short answer, no there is no Trans life monitor. The only thing Trans related is the v showing the fluid temp, among other extras the v shows.
    The post is titled oil in the v6 Trans which he probably brain farted and meant to say engine. I think btlegacy answered his question.
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,496
    I've only seen it in the SRX. But apparently some CTS cars had it as well.
    Sent from AutoGuide.com Free App
    ddalder's Avatar
    Aug 2008
    Canada
    2,800
    Quote Originally Posted by Guy.Seminerio View Post
    No, that is not entirely correct. I can use my Tech2 to determine the percentage of transmission fluid life remaining. This is something GM had been working on, but from what I understand, was never developed to the point it was implemented on a large scale basis.
    mjcaddy's Avatar
    Oct 2010
    Chicagoland
    32
    421
    That's why i said if your car have it, I don't have it on the 09 but i do in my srx so i thought maybe they removed this feature somewhere in between 05 and 09.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    My '04 CTS had a trans life monitor, not the STS though...
    ddalder's Avatar
    Aug 2008
    Canada
    2,800
    I have the transmission oil life monitor in both my 2004 Bonneville GXP (same engine and transmission as the DeVille) and my 2008 STS. However, there is no way to view/access the information without my Tech2. The photos below are from my STS.
    Feb 2013
    Whitestone, NY
    28
    3,211
    Interesting. I'm gonna roll the dice and say that the op is referring to resetting the oil life percentage on the driver information center. Pretty cool stuff though.
  16. Remove Advertisements
