What signs do i need to be on the look out for when it comes to my GM 3.6 engine oil?
Results 1 to 4 of 4
Cadillac STS Forum - 2005 through 2012 Discussion, What signs do i need to be on the look out for when it comes to my GM 3.6 engine oil? in Past Cadillac Vehicle Discussion; What are all the important signs i need to be aware of for the GM 3.6 engine oil in my ...
    viccampjr's Avatar
    viccampjr is offline Cadillac Owners Member
    Automobile(s): 2007 STS
    Jul 2013
    Clifton, NJ
    18
    What are all the important signs i need to be aware of for the GM 3.6 engine oil in my 2007 STS?
    I just bought a 2007 STS all wheel drive with 58,000 miles on it and was wondering if i might incounter any oil problems with this year cadillac.
    Are there any 2007 STS owners that never had any oil problems with their GM 3.6 ?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,063
    Re: What signs do i need to be on the look out for when it comes to my GM 3.6 engine
    Just check it regularly, get a good handle on how much it goes through, if any. You may never have an issue at all, but just be aware that the 3.6 is known for using oil causing premature timing chain wear.
    Do some reading over in the 1st Gen CTS forum, TONS of information over there regarding this issue. Also, you could try reaching out to a member on here from FL, SC2150. He works with a company that has done significant work on the 3.6L LY7 engine and I'm sure he could give you a better idea as to what to expect and measures you can take to prevent it.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Least with an 07 he has extended timing chain warranty. Else I would run from a 3.6 and its oil consumption timing chain (that apparently doesn't exist per GM) problems.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,063
    Yes, good reminder 1Bad...
    Your timing chain is covered for, IIRC, 10 years or 120k, under an extended coverage adjustment that was made by GM.
  7. Remove Advertisements
