Rear leveling - Page 2
Results 16 to 30 of 32
Like Tree2Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Rear leveling in Past Cadillac Vehicle Discussion; I just measured my car that has been off for 24+ hours and has FE3 w/ MRC. Front = 28.5" ...
  1. #16
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,497
    Re: Rear leveling
    Front = 28.5"
    Rear = 28.25"
    Tank full, empty trunk
    And since my Monte Carlo was next to it... (it has FE3 as well )
    Front = 28.25"
    Rear = 28.0"
    Tank 1/2 full w/ two 12" subs in 2 boxes.
  2. #17
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Rear leveling
    All sounds within normal range. I posted the two in my garage a few days back. I think the AWD 1SG was about 1/2" lower in back than the 1SE Hertz.
  3. #18
    STS-4000's Avatar
    STS-4000 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS-4 1SG, ACC, HUD, F55/FE3
    Jun 2012
    Kansas City, MO
    29
    143
    Re: Rear leveling
    Quote Originally Posted by Ludacrisvp View Post
    Front = 28.5"
    Rear = 28.25"
    Front = 28.25"
    Rear = 28.0"
    Sorry this may be a stupid question, but how are you measuring it? Are you measuring from the ground up to the fender?
  5. #19
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,497
    Re: Rear leveling
    Quote Originally Posted by STS-4000 View Post
    Correct, from the ground to the highest point on the fender (top of the arch).
    Both cars parked in the garage on cement floor.
    Wasn't sure of where else to use as measurement points.
  6. #20
    STS-4000's Avatar
    Jun 2012
    Kansas City, MO
    29
    143
    Re: Rear leveling
    Ah okay I thought so. I bought a tape measure on my way to work yesterday and i wasn't sure how to measure it, but now I know.
    Thanks.
  7. #21
    STS-4000's Avatar
    Jun 2012
    Kansas City, MO
    29
    143
    Re: Rear leveling
    Alright so I measured my ride height and this is what I got.
    Front=28.75"
    Rear=27.5"
    And these measurements were made after letting the car idle for about 5 minutes.
  8. #22
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Rear leveling
    4000- My AWD is half an inch lower in back than front. I think yours is high in front and low in back. Are you on stock suspension, wheels & tires?
  9. #23
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,497
    Re: Rear leveling
    I agree with E ...
    what are the tire sizes on front and rear?
    anything in the trunk?
    has anyone replaced any suspension components?
    proper tire pressure?
  10. #24
    STS-4000's Avatar
    Jun 2012
    Kansas City, MO
    29
    143
    Re: Rear leveling
    Front 235/50-18
    Rear 255/45-18
    I removed my 80lb toolbox out of the truck before measuring it and as for as I know the suspension is stock.
  11. #25
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Rear leveling
    Try driving it around for a while with an empty trunk and then measuring. I think there's a leveling problem.
  12. #26
    STS-4000's Avatar
    Jun 2012
    Kansas City, MO
    29
    143
    Re: Rear leveling
    Alright tomorrow I'm gonna empty my trunk out and drive it around and measure it afterwards.
    Oh btw, sometimes I can hear the air compressor turn on for about 2 seconds and then turn off and the car's ride height won't budge.
  13. #27
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,900
    Re: Rear leveling
    I hate to say this, but floor-to-fenderwell measurements have absolutely NOTHING to do with ride height measurements. Two different tires or even different tire inflation pressures (on different cars) can throw that measurement off by as much as 0.5" or more.
    Suspension heights are measured using a specific set of specs from the service manuals - it's related to the geometry of the lower suspension arms, and there is a specific set of loads that are used when doing the measurements.
    ELC compressors (systems) do a prove-out shortly after Key:ON - you'll never see a height change during that sequence.
    Turn the Key:ON and let the ERC do its preload. Pop the trunk - 3 of you hop onto the open trunk lip. ELC should level the rear. All hop off - you should hear air escaping in the RR wheelwell as the system again levels the rear.
    dkozloski and mckellyb like this.
  14. #28
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    Quote Originally Posted by curtc View Post
    If not equipped with MRC the rear leveling is done by the shock itself rather than an air compressor...Google "Nivomat" to find out how they work.
    I know how nivomats work. I though they were only available on the cts. Can I get nivomat shock and replace my air shocks with these
  15. #29
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Yes but you must bypass the Magride sensor or you'll get suspension messages and be speed limited to 80 mph.
  16. #30
    mckellyb is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS N*, 1SF, 144K mi.
    Apr 2011
    Fort Worth
    650
    Re: Rear leveling
    Submariner409 nailed it.
    The only time I've heard my compressor, and I was listening for it, was when I put 12 cubic feet of mulch in the trunk (in bags) with another two 40 lb. bags of fertilizer stuffed in there.
    Even then, it was very quiet.
  17. Remove Advertisements
