Climate Control Actuator
Results 1 to 5 of 5
Cadillac STS Forum - 2005 through 2012 Discussion, Climate Control Actuator in Past Cadillac Vehicle Discussion; ...
    jkharnage is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac STS
    Feb 2009
    Trempealeau, WI
    68
    Well, itís time to replace the one of the actuator motors for the climate control system. However this one is in a very awkward place and it looks as if I have to remove the dash board to get to it. Iíve checked the forum but donít see any information to assist me for my 05 STS on dashboard removal unless thereís an easier way to get to this actuator. I know itís the culprit since it keeps moving the door while the climate control system is off. I can tap on it with a screwdriver and it will stop moving the door. I have the part (GM 89023388) and I see another actuator near it. I might replace it too since I could possibly go the distance to remove the entire dashboard. Any assistance would be greatly appreciated.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Climate Control Actuator
    It may only need the arm. Try lube first. Then the arm. Only change the assembly if you nust; that's rare.
    Feb 2009
    Trempealeau, WI
    68
    Just curious but what kind of lube would you recommend for the arm? Also, would it be possible that the arm of the actuator is getting hung up in the cam. Maybe a small bur or piece of plastic is holding up the actuator? The biggest issue is getting it out to examine.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I don't have a favorite. Koz uses some special lithium bear fat on his...
    DarkMingBlueSTS's Avatar
    DarkMingBlueSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 6 CYL
    May 2012
    497
    Quote Originally Posted by jkharnage
    I used spray able white lithium grease on mine
  8. Remove Advertisements
