Rear Strut/Air bag leak
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Ludacrisvp
Cadillac STS Forum - 2005 through 2012 Discussion, Rear Strut/Air bag leak in Past Cadillac Vehicle Discussion; shock.jpg After checking brake pad wear, I noticed squeezing the air bag made a hissing sound. Poured some soap on ...
    Midnight is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 1SG
    Nov 2009
    Baltimore
    41
    308
    After checking brake pad wear, I noticed squeezing the air bag made a hissing sound. Poured some soap on it and you can see where the air is coming out. This isn't normal right? I mean, if you were to "blow" into the inflation valve it just bleeds right out the top. I figured if it went bad, it'd be on the rubber part, it's pretty surprising to me that it'd be on the top.
    I have never noticed my car sitting low or anything, and it's something I notice quite a bit when other cars are, but I guess I don't often carry a lot of heavy things back there either.
    Here's the label on the front of the strut in case someone is wondering.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Air should only come in and out of the valve where the air line connects. Anything else is a failed strut bag.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,499
    Re: Rear Strut/Air bag leak
    I would replace it sooner rather than later. Not sure how long your compressor will last being on all the time to compensate for the leak.
    mckellyb likes this.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by Ludacrisvp
    Correct!!!
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    yep. On previous caddy's with the air suspension in the back, I've had leaks but caught them early. The only way I knew was that when there was a load in the back, about 50% of the time I'd hear the compressor working but the car remaining low. But with no load, the car looked normal. If I never changed it, I'm sure I'd eventually see sagging with no load.
    Nov 2009
    Baltimore
    41
    308
    Thanks guys. Going to see if Rippy can hook me up with a new one.
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    Quote Originally Posted by Midnight View Post
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=121633"/>
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=121641"/>
    Same place mines leaked at. I was shocked also that it would leak there rather than the bag itself. Weird if you ask me. Maybe a flaw in design
  10. Remove Advertisements
