installing Camshaft Position Actuator Housing Assembly
Results 1 to 5 of 5
Cadillac STS Forum - 2005 through 2012 Discussion, installing Camshaft Position Actuator Housing Assembly in Past Cadillac Vehicle Discussion; I Removed the Camshaft front cover on my 2005 Cadillac STS, V8 Northstar Engine. I am in the process of ...
    browncoug is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac STS
    Aug 2010
    I Removed the Camshaft front cover on my 2005 Cadillac STS, V8 Northstar Engine. I am in the process of replacing the gaskets and reinstalling it but I would like some better instructions on how to align the position actuator solenoids to the camshaft position actuator oil control valves on the end of the camshafts. I have the GM manual with the b/w pictures but it is still not clear. Does anyone have better instructions they could share with real pictures maybe??? Please help.
    gm instructions.http://www.justanswer.com/cadillac/4...-cadillac.html
    Charles Warren's Avatar
    Charles Warren is offline Cadillac Owners Fanatic
    Automobile(s): 2008 sts-v black raven 2004 cts black raven
    Nov 2011
    Atlanta, Georgia, United State
    88
    459
    Re: installing Camshaft Position Actuator Housing Assembly
    I read instructions myself. They sometimes say tools and it could be an awl in this case. Like they say special tool when replacing rear differential but you can use a pry bar. How did it turn out op?
    dawgy2219 is offline Cadillac Owners Member
    Automobile(s): sts
    Jun 2010
    18
    I am also trying to replace the camshaft position actuator solenoid for intake and exhaust on my 2005 sts v8. Any part numbers on them? Also, do they need to be reprogrammed by the dealer or is that just for the sensors not the actuator solenoids? Any help would be appreciated!
    Brent Messing is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac STS4 V8 w/ all the options
    Aug 2011
    Minneapolis, Minnesota
    23
    My northstar is leaking in the same locations and I was thinking about looking into it. Any advice would be appreciated.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    My advice have a dealer do it. Mine were replaced 3 times due to improper install.
  8. Remove Advertisements
