Delay when turning car off and opening door
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Cadillac STS Forum - 2005 through 2012 Discussion, Delay when turning car off and opening door in Past Cadillac Vehicle Discussion; So typically when I turn the car off and open the door, almost instantly my steering wheel goes up and ...
    Relate27 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS4 1SB
    Jun 2008
    137
    So typically when I turn the car off and open the door, almost instantly my steering wheel goes up and my seat adjusts to a lower level making it easier to get out of my car. Over the past 2 weeks I have noticed a delay now and I am wondering what could be causing it and if anyone else had this same experience. RIght now it's anywhere from a 5 second delay to 1 minute delay , most times I just get frustrated with waiting for my steering wheel to adjust and manually move it up before exiting the car.
    Is the battery in my FOB going out, I'm not really sure why that would cause the issue I'm having but I honestly can't think of anything to cause the issue. Thanks for your help !
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    2,020
    That's weird. I haven't heard of that one in the forum before.
    Good luck.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,711
    Re: Delay when turning car off and opening door
    Quote Originally Posted by Relate27 View Post
    Hello Relate27,
    I apologize for this malfunction with your vehicle you are experiencing. I am unable to offer technical advice, because I am not a certified technician. We rely on our dealerships for their technical expertise. If you would like help in setting up a nearby dealership appointment, please let me know. We can further discuss your issue if you private message me. Be sure to include your contact information, VIN and current mileage.
    Regards,
    Laura M.
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,856
    When you open your door does the stereo shut off immediately, or is there a delay with that also?
    Jun 2008
    137
    The stereo shuts off immediately. I took a crappy video of the delay, it's dark but you can hear the door open and notice the delay. Typically once the door is open the steering wheel and seat adjust instantly no delay. ALSO that is a short delay, it does go longer like up to a minute sometimes, this has only been happening recently
    ddalder's Avatar
    Aug 2008
    Canada
    2,856
    This is unusual behaviour. I was originally thinking about an intermittent switch or wiring related to the door latch mechanism (this detects when the door is ajar and will trigger the stereo to shut down, seat/column to reposition, etc). Since the stereo shuts down immediately, I don't believe this will be the source of your problem. Since it involves both the seat and the column, I suspect it's not just a simple (common) connection problem. Because most aftermarket scan tools have limited or no ability to get into body (non-engine/transmission) codes, this may require a visit to a dealership or shop with a Tech2. You can try disconnecting the battery and touching the cables together briefly. The accepted standard practice is to disconnect the negative first and reconnect the negative last. This has been know to correct erroneous problems on occasion.
    Jun 2008
    137
    Thanks for the replies ddalder I appreciate the advice. I guess I can try and disconnect the battery and see what happens. Before I do that did I read correctly that once the battery cables are disconnected you touch the battery wires together ?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Yes. Touch them together, this will reset the various modules in the car. I was very hesitant to do it myself but it doesn't hurt a thing. I actually have to do this in my own STS from time to time to get my audio system to work again. It just randomly stops working once in a while, hasn't done it for some time now (knock on wood) though...But, the battery method does the trick each and every time.
    ddalder's Avatar
    Aug 2008
    Canada
    2,856
    Yes, that's correct. Most modules will have capacitors installed across the ground & +12V supply to assist in filtering electrical noise. These can hold a charge and touching the cables will cause them to discharge. This ensures the modules will completely reset. The modules themselves should drain whatever charge these capacitors may briefly hold, but it is an extra step to ensure they discharge fully.
    I questioned a GM dealership service manager once about this. The modules should draw enough current that doing this isn't necessary and the capacitors should discharge quickly on their own (unless they are quite large). He advised me that it didn't seem to make a great deal of sense to them either since the modules are always active and drawing power, but their GM Technical Assistance Center (the place technicians call for assistance) advises them to do this and it does occasionally work.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    You may have to recalibrate the Express Windows but I haven't. The procedure is in the owners manual and takes a minute.
    Maximln is offline Cadillac Owners Enthusiast
    Automobile(s): 08 STS V8 AWD, 1SG, Platinum Edition
    Jan 2003
    Fresno, CA
    678
    I am having the exact same problem. 75% of the time, everything works fine. When I open the door, the steering wheel immediately moves up & back. Recently, when I open the door, nothing happens for a few seconds or longer. It's like the computer does not know the door is open. Cars used to have a little switch to operate the interior lights, key buzzer, etc. There must be something in the door that tells the car it is open but it must be integral to the latch or something because I cannot find one.
    ddalder's Avatar
    Aug 2008
    Canada
    2,856
    Quote Originally Posted by Maximln View Post
    Yes, these are integral to the latch assembly on many 2000+ GM vehicles and pretty much everything current day.
    Jan 2003
    Fresno, CA
    678
    So in order to fix the issue, you have to replace the latch assembly?
    Thanks,
    Max
  16. #14
    ddalder's Avatar
    Aug 2008
    Canada
    2,856
    Yes, if that's the problem. In the case identified by the OP, when the door was opened, the stereo immediately shut off despite the fact that the exit position was not immediately set. This suggests that in at least that case, the problem is elsewhere.
    I would definitely make some other checks before ordering a new latch assembly.
  17. #15
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    OP didn't post a response to the system reset.
    Hey Relate! Did it help?
  18. Remove Advertisements
