Traction Indicator
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Like Tree4Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Traction Indicator in Past Cadillac Vehicle Discussion; Now, when I make a sharp left turn, the traction indicator lights, and I hear the noise it's designed to ...
    maiahsdad's Avatar
    maiahsdad is offline Cadillac Owners Fanatic
    Automobile(s): 05 STS AWD 1SG
    Apr 2009
    Fishers, Indiana, USA
    484
    Traction Indicator
    Now, when I make a sharp left turn, the traction indicator lights, and I hear the noise it's designed to make when this feature is enabled. But.... It's dry and sunny out, and nothing to slip on. Seems like yet another expensive problem with this car.
    Thoughts gang?
    carter's_sts is online now Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    2,015
    Sounds like wheel sensor. I think you have to replace the hub.
    curtc and curtc like this.
    maiahsdad's Avatar
    Apr 2009
    484
    Quote Originally Posted by carter's_sts
    Wonderful...
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Re: Traction Indicator
    if you are turning left when this occurs it is more than likely a passenger side bearing as that is where the weight is being shifted...Does the sound come from the front or rear of the vehicle? That will tell you which one needs replacing. This should not require a dealer visit. If you can change your own brakes you can change a wheel bearing...If not, just find a reputable local shop to do this one to save on labor costs, it's not hard at all.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    What are your tires,their age & pressures? Both my wife & I saw this regularly with old OEM rubber. No more.
    Charles Warren's Avatar
    Charles Warren is offline Cadillac Owners Fanatic
    Automobile(s): 2008 sts-v black raven 2004 cts black raven
    Nov 2011
    Atlanta, Georgia, United State
    88
    459
    i was gonna say check tires first too
    maiahsdad's Avatar
    Apr 2009
    484
    Well gang, I have just gotten my car back from the body shop after being repaired from the accident. I'm not sure if most of you remember that I was backed into by a huge SUV about a month ago. Now, the traction control light is illuminated, and pressing the button on the middle console does NOT turn it off.
    They didn't do anything with my tires, just replaced the hood, left headlight (now it looks stupid with one new and one dull), lower mesh in front of the grill, and the grill. Doesn't feel like the 4-wheel Dr. feature is working now. But maybe it still works even though the traction control light is constantly on (as if I have disabled it via the button on the console). I'm a little worried (no, pretty damn scared in all this snow) because I can't press the button and turn the traction control on or off. It's constantly lit. Also, the service brake assist, and service stability system messages are on the screen.
    Lastly, the steering is very tight or harder to turn now while driving down the road. It's almost like the power steering is working, but barely working. Is that type of feel. If I want to change lanes going down the highway, I just can't use one finger to move over. I have to work harder to turn it left or right. Seems a little easier when I'm in a parking lot but not much at all. I don't remember it being this tight to steer.
    targetSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cadillac STS AWD 1SG
    Mar 2011
    34
    401
    you can't turn off what turned off already, I talk about TC. When problem with any wheel sensor exists, ABS\TC\Stability system stop working cause all of that is one system. So check your hub bearings ( almost every hub bearing should be replaced once for 05 STS ))).
    Regarding power steering - change your power steering fluid first, check for leaks. If it not help check power steering pump.
    maiahsdad's Avatar
    Apr 2009
    484
    Quote Originally Posted by targetSTS
    you can't turn off what turned off already, I talk about TC. When problem with any wheel sensor exists, ABS\TC\Stability system stop working cause all of that is one system. So check your hub bearings ( almost every hub bearing should be replaced once for 05 STS ))). Regarding power steering - change your power steering fluid first, check for leaks. If it not help check power steering pump.
    so you are saying that this could have nothing to do with the front end collision I had? I didn't experience this prior to then. But yes, the ABS, TC, Brake Assist, Stability Sys all are lit.
    maiahsdad's Avatar
    Apr 2009
    484
    So, does the four-wheel-drive function still operate even though there is no traction control enabled?
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by maiahsdad
    Our cars are all time all wheel drive. It's mechanical not electric. Only way to defeat it is a snapped chain in the t case or removing the front driveshaft. Otherwise your running all 4 wheels no matter what "button" you press or electronic failure that shuts down tc andr stabilitrak andr abs.
    maiahsdad's Avatar
    Apr 2009
    484
    Quote Originally Posted by 1BadCadSTS
    I was wondering because the other day, I tried to make it up a friends driveway and couldn't. He shared with me that only the rear wheels were spinning.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Time to jack up the rear of your car and floor it huh hahahahhaha.
    I'd bet the front wheel on opposite side was spinning.
  16. #14
    maiahsdad's Avatar
    Apr 2009
    484
    Time to jack up the rear of your car and floor it huh hahahahhaha. I'd bet the front wheel on opposite side was spinning.
    LOL! HAHAHAHAHAHAHA! Maybe so! So they ALL FOUR would be pulling like my Jeep Commander? I thought they all pulled all the time! All Wheel Drive =All Wheels Pulling.... :-/
  17. #15
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,548
    All wheel drive is really one wheel front and one wheel rear having power with the car using TC to alternate power to each side.
    johnny-cash likes this.
  18. Remove Advertisements
