Transmission issues?
Results 1 to 8 of 8
Like Tree1Likes
  • 2 Post By EChas3
Cadillac STS Forum - 2005 through 2012 Discussion, Transmission issues? in Past Cadillac Vehicle Discussion; A little nervous here. When I hit around 45 mph, I get a little shudder that lasts a few seconds. ...
    BIGGUYRJ is offline Cadillac Owners Member
    Automobile(s): 2005 STS V6
    Jun 2013
    17
    A little nervous here. When I hit around 45 mph, I get a little shudder that lasts a few seconds. About the same speed when I begin to brake, I get a slight surge in speed. Just bought this 05 a couple of months ago and it only has 43k on it! Me thinks it has something to do with the torque converter, perhaps?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Re: Transmission issues?
    I believe there is a TSB for that exact issue, the TC is the culprit from what I've read here.
    Jun 2013
    17
    I can't find where the TSB notices are. I remember seeing them somewhere...
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    GM Bulletin #06-07-30-030A: 5L40-E/5L50-E Transmission Torque Converter Clutch (TCC) Surge, Shudder, Exhaust Moan, Chuggle Noise at Low Speed and Light Load (Reprogram TCM) - (Sep 5, 2007)
    Subject: 5L40-E/5L50-E Transmission Torque Converter Clutch (TCC) Surge, Shudder, Exhaust Moan, Chuggle at Low Speed and Light Load (Reprogram TCM)
    Models: 2004-2007 Cadillac CTS
    2005-2007 SRX, STS
    with V6 (VIN Codes 7, N, T -- RPOs LY7, LA3, LP1)
    2004-2006 SRX
    2005-2006 Cadillac STS
    with V8 Engine (VIN Code A -- RPO LH2)
    Condition
    Some customers may comment on a shudder, surge or chuggle on light throttle under light load just after torque converter clutch (TCC) . Others may comment on an engine exhaust moan in the 1200 RPM range between 65-73 km/h (40-45 mph). This occurs with the transmission at normal and commanding the TCC off with the scan tool will eliminate the concern.
    Correction
    New transmission calibrations have been released to correct this condition in both V6 and V8 applications. Reprogram the TCM using SPS. This new service calibration is available on TIS2WEB.
    After reprogramming the TCM, if the condition persists and mileage is greater than 40,234 km (25,000 mi), replace the torque converter, flush the transmission, and replace the transmission fluid.
    If the condition still persists, contact the Technical Assistance Center (TAC).
    Hope that helps
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by BIGGUYRJ View Post
    Hello BIGGUYRJ,
    I apologize that you are experiencing a transmission issue with your STS. If you are interested in taking it back to the dealership to have them try and diagnose the concern you are experiencing, I would be more than happy to assist. Please private message me your name, contact info, VIN, mileage, and dealership you would like to work with if that is the route you would like to pursue. Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    V8 STS only, but yeah. My TC was < $900 at dealer under extended warranty. My AWD V8 had rough low-speed downshifts at about 80,000 miles.
    turnne is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac STS
    Oct 2007
    Indianapolis Indiana
    52
    1,209
    Famous "chuggle"...very common according to my Cadillac dealer who replaced my TC
    SRX was highly prone as well they told me
    First step...reflash the trans......if that doesnt work....then
    second step...replace the torque converter.....this worked for me....$1300 paid under warranty....but if this didnt work then
    third step...rebuild the trans
    Warren
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Never had 'chuggle'. They did update my TCM and I miss the old program. I may end up with doing business with Madtuner when the warranty is done.
    Ludacrisvp and Ludacrisvp like this.
  11. Remove Advertisements
