If timing chain breaks, would it..... - Page 2
Results 16 to 30 of 33
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, If timing chain breaks, would it..... in Past Cadillac Vehicle Discussion; Yea I never thought about the chain simply skipping a tooth. Could very well be....
  1. #16
    truckinman is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac STS 3.6
    Apr 2012
    Columbus OH
    31
    1,219
  2. #17
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,528
  3. #18
    Apr 2012
    Columbus OH
    31
    1,219
    Got the call. It's a fuel pump. Still a grand to replace. But better than a seized enginne
  4. #19
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,780
    Re: If timing chain breaks, would it.....
    Figured it was something like that. I really couldn't see it being the hood switch. You can start and operate your car with the hood open. The hood switch is primarily to disable the remote start if the hood is open. This is a safety feature so someone can't accidentally remote start it while someone is working under the hood.
  5. #20
    Apr 2012
    Columbus OH
    31
    1,219
    Quote Originally Posted by ddalder
    Well does anyone know just how hard a fuel pump replacement is in one of these? He told me most of the cost was labor. I'm thinking I may tackle this job on my own. We've got 3 cars so if it takes a while so be it.
  6. #21
    ddalder's Avatar
    Aug 2008
    Canada
    2,780
    Quote Originally Posted by truckinman View Post
    The fuel pump will be in the fuel tank. In some cars you can access the pump through an access panel in the trunk... just not these cars. You'd need to drop the tank which is why it's so labour intensive.
  7. #22
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,478
    Parts Information OEM Part # Price
    Fuel Pump 19151141 $374.11
    Labor Information Skill Level Mfg. Warranty Standard
    B 3.0 4.6
    Does Not Include: Drain & Refill Fuel Tank.
    Pump appears to be on the passenger side of the tank based on images from service manual.
    If you were thinking of doing this on your own it looks like a special tool is needed:
    Fuel Pump Lock Ring Tool AST tool# J 45722
    Fuel pump lock ring tool that can be used on GM and Saab vehicles
    Contact AST for pricing "Assenmacher Specialty Tools"
    1 800 525 2943
    But there is also this:
    Primary Fuel Tank Module Replacement
    Tools Required
    J 45747 Fuel Tank Sender Wrench
    Secondary Fuel Tank Module Replacement
    Tools Required
  8. #23
    Feb 2010
    Sunbright, TN
    1,528
    Neato
    http://www.justanswer.com/cadillac/3...-2005-sts.html
    There was a hack way.
    Pull the back seat. Cut an access hole over fuel pump. remove and replace pump. patch the new access panel you made.
  9. #24
    ddalder's Avatar
    Aug 2008
    Canada
    2,780
    I can't imagine for a moment that I'd ever consider cutting new holes in my vehicle for something like this. Not to mention if the tank or line(s) were damaged while cutting the metal, it could lead to a catastrophic event. Some people should not be allowed to own or use tools.
    Ludacrisvp and Ludacrisvp like this.
  10. #25
    Apr 2012
    Columbus OH
    31
    1,219
    No way in hell would I cut new holes. Lol. I dismissed that idea soon as I read it. When working around gas, the last thing I wanna do is create sparks
    I actually knew a guy who was doing this very job but on another type of car, as he was lowering the fuel tank, a spark was created and blew the garage up. Killing him instantly. So I don't take this stuff lightly
  11. #26
    orange57's Avatar
    orange57 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS Northstar RWD
    Nov 2010
    Phoenix, AZ
    34
    511
    Quote Originally Posted by amunderdog View Post
    Neato
    A 96 saab 900 I had, had a small hole under the rear seat to access the electrical connector to the fuel pump. When it I cut the hole bigger. Was about 2in diameter before, an 8in after. A small piece of scrap metal, sheetmetal screws and gasket material and the hole was patched. Just have to size the screws so you don't puncture the tank
  12. #27
    ddalder's Avatar
    Aug 2008
    Canada
    2,780
    Quote Originally Posted by orange57 View Post
    Respectfully, my position remains unchanged. Apart from the obvious hazards already mentioned, there is too great a risk of not properly sealing this from the top side. Salt, calcium and/or other anti-icing agents will start to rust and corrode the area. Even to seal it from the underside requires adequate surface prep. Proper access to do this is unlikely without moving the tank anyway.
  13. #28
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    There's doing things and doing things right.
    Daddler and I reside in the same camp on this.
  14. #29
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,478
    Quote Originally Posted by 1BadCadSTS View Post
    ddalder and I reside in the same camp on this.
    I'm in the same camp as well on this one.
    You just don't **** around any time you're dealing with a bomb.
  15. #30
    orange57's Avatar
    Nov 2010
    Phoenix, AZ
    34
    511
    The Saab already had the small hole. And in AZ there isn't much risk of salt and rust. Plus 220k on the clock I wasn't too worried. If there wasn't already a hole I likely would have dropped the tank. But go figure that one failed right after I filled up ha ha
  16. Remove Advertisements
