Rear suspension actuator?
Results 1 to 5 of 5
Cadillac STS Forum - 2005 through 2012 Discussion, Rear suspension actuator? in Past Cadillac Vehicle Discussion; So i recently replaced my rear shock/compressor/air lines do to a bad shock and everything work great. Everything worked great ...
    shortfur7's Avatar
    shortfur7 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS4 2.0
    Jul 2011
    31
    143
    So i recently replaced my rear shock/compressor/air lines do to a bad shock and everything work great. Everything worked great for about 3 days then i got a service suspension system message on my dash. So i had the local shop run through it with a scanner and they said it was isolated to a left rear actuator on the suspension. I tried to look for the part online and i cant figure out what part it is. Does anybody know which one it would be? I have a 2005 N* magnaride suspension.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    There is no "actuator" on F55 dampers, actuators were part of the older F45. What was the code?
    If the definition he got was for an actuator, it still points towards the shocks control circuit. Check the connector first.
    Wait, you replaced only one shock? The one triggering the code? Was it replaced with a MagnaRide shock?
    shortfur7's Avatar
    Jul 2011
    31
    143
    Re: Rear suspension actuator?
    No i replaced all the shocks including the air lines and compressor. I am wondering if he ment to say its the sensor? Which would be GM 88957145. I dont know what the code was because i wasnt having them do the work so he wouldnt tell me.
    Sep 2010
    East Boston MA.
    29
    26,325
    They wouldn't tell you the code?
    Go to a parts store and have them pull the codes.
    If it is for the ride height sensor, check the connecting rod first.
    shortfur7's Avatar
    Jul 2011
    31
    143
    Auto parts stores don't have the right scanner to pull this type of code. What would I check on the connecting rod? Is it adjustable?
  8. Remove Advertisements
