The fact that I got Cadillac with wheels from a newer model and the sensors are not suitable to the system and I do not want to spend now 250 ~ 300 bucks for four new sensors
It can't be turned off. Once the option for tpms is set in the module it can't be changed. You could try getting another bcm and programming it without tpms if it allows you to select options. Do not buy aftermarket sensors either. Seen to many fail.
'Can't' is probably the wrong word. With enough effort and money, most things can be accomplished.
My advice is to fix it. If you didn't save your sensors, most members report the aftermarket sensors last at least half as long as GM's. My OEM experience is > 8 years, since I've only replaced 1/8. That puts aftermarket life > 4 years.
YMMV
If $200 for 4 sensors installed ($140 parts & $60 labor) hurts your budget, you may have bought the wrong car.
I said it "can't" be turned off with his current module. Don't matter how much money you got, module is burned already to have tpms and can't be changed. Anyway....
Today changed the sensors and it worked. The problem is that the wheels were from the export model with TPMS UH3 and my Caddy bought in the U.S. "domestic" model with TPMS UJ6. Already changed tires. Tires in Israel from the heat dries and cracks in 3-4 years. Total paid about $ 1000 ... not so few.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
