2007 STS-4, V6, 30 days CPO left, what should I have checked out?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Cadillac STS Forum - 2005 through 2012 Discussion, 2007 STS-4, V6, 30 days CPO left, what should I have checked out? in Past Cadillac Vehicle Discussion; I just traded off my 2003 CTS with 204K miles for a 2007 STS-4 with 37K miles. Turns out it ...
    Fleetwood49 is offline Cadillac Owners Member
    Automobile(s): 2007 STS-4, 1949 60S Fleetwood
    Apr 2011
    55
    22
    Turns out it is Certified Pre-Owned and I have 30 days of the bumper to bumper left.
    It's going in to the dealer, what should I specifically ask them to check out on the car.
    Thanks!!!!!
    malatu's Avatar
    malatu is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS 3.6 AWD
    Dec 2005
    1,005
    Re: 2007 STS-4, V6, 30 days CPO left, what should I have checked out?
    Timing chain.
    I had mine replaced with less than 30 days left on the cpo.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Quote Originally Posted by Fleetwood49 View Post
    Thanks!!!!!
    Hello Fleetwood49,
    Congrats on your 2007 STS-4! It will be a fun car to drive.
    Regards,
    Laura M.
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,979
    Seat cushions.....bulletin for loose/squeaky.
    Every light bulb.
    Nav system firmware upgrade....tell them you have Bluetooth issues. Not positive this applies to 2007 models though.
    Check for any oil leaks.
    If you have MRC, check for leaks from the shocks.
    Read all stored codes.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Carter is spot-on about the Nav firmware upgrade. Get 'Bluetooth connection issues' on a service order and you're protected. It does apply to most 2007's.
    For the rest pertaining to a V6, I'd get the oil changed and have a driving Memorial Day weekend to get a good read on oil consumption and be on guard for loss & timing chain concerns.
    Good luck!
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    fleetwood, Some of the early V-6 will burn a lot of oil, 1 quart per 700 miles. Door micro switch will go bad & then you will have to use the key to gain entry. The transmission torque converter can be a problem. Leaking seals on the real diff, check for oil stains. Danny
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I forgot about the diff seal. It's probably already been done.
    Apr 2011
    55
    22
    Thank you to everybody who replied.
    This is great, and really helped.
    Car is going in Friday for a check up.
    Apr 2011
    55
    22
    I haven't been able to locate a bulletin regarding loose/squeaky seat cushions.
    Can you help me out with the number?
    Thanks!!!
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    See the 'Sticky' thread at the top of the forum. If they are loose, the fix is to remove the rails & insert a split section of small-diameter rubber hose, like vaccum hose.
    If your seats aren't loose in the rails, you don't want this because it could cause early death to seat adjustment motors.
    Jun 2009
    1,979
    Make sure you read through that thread. There's more than one TSB for the seats, but I was definitely referring to the one that uses the rubber hose cut in half. I had it done to both my STSs, both front seats.
    I'm picky, but a Lac should not have loose seat cushions.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    I know this is a few days old but I'd say to definitely extend the bumper to bumper before it's too late!
    KRSTS Guest
    Get a GMPP Major Guard warranty BEFORE the CPO expires. Otherwise you wont be able to, and will have to settle for an aftermarket warranty. I found that James E. Black Cadillac had the best prices: http://www.jamesblackcadillac.com/gmpp.htm I wouldn't go without a warranty - especially with the low miles this cars has.
  16. #14
    Apr 2011
    55
    22
    Black Cadillac told me that my car doesn't qualify for the GMPP. It's 1 year from expiration of original factory warranty-fyi.
    Car has been at the dealer over a week, getting worked on, waiting for parts. Granted I've been driving a 2013-ATS-V6 all week.
    Now that's a Cadillac!~!!!!
  17. #15
    Jun 2009
    1,979
    ATS is tooooooo small.
    Why did they say you can't get a GMPP if you're still under factory warranty? Is that because it's only available when the car is sold?
  18. Remove Advertisements
