STS not starting. Did everything possible. Its driving me crazy.
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Cadillac STS Forum - 2005 through 2012 Discussion, STS not starting. Did everything possible. Its driving me crazy. in Past Cadillac Vehicle Discussion; I have a 2005 STS V6. When you try to start the car, everything cuts off and nothing happens. about ...
    crazyburr is offline Cadillac Owners Member
    Automobile(s): STS
    May 2013
    30
    5
    I have a 2005 STS V6. When you try to start the car, everything cuts off and nothing happens. about a min later, everything turns back on, including gauges, and just sits there. I have changed the battery, the starter, the relays, the starter switch. alternator is good. i have no clue what to do next?
    could it be the Neutral safety switch. when i press the brake before starting it, i hear the NSS click. i have shifted car into neutral to try to start it, it wont work. sometimes if i take off one of the battery terminals, it seems like it resets the car and car will start. i have never had it do this to me in the afternoon, only cold starts in the morning.
    i feel like there is a short somewhere causing this. any help would be much appreciated. thank you.
    KRSTS Guest
    Re: Sts not starting. Did everything possible. Its driving me crazy.
    Get it to a dealer. You have probably spent more by throwing parts at it than a dealer visit will cost you.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,028
    Is the SES light on? Have you had the codes scanned?
  5. #4
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Check all the fuses? Is the security light on?
    Sounds like my rcdlr when I swapped it to one with the secure car feature. I figured I'd try starting it but no luck. Did exactly what you describe. Had to perform the 30 min security relearn then erase and program the fobs.
  6. #5
    Automobile(s): STS
    May 2013
    30
    5
    Quote Originally Posted by curtc View Post
    no ses light on.
    Quote Originally Posted by 1BadCadSTS View Post
    no security light on, and all the fuses are good.
    its weird, once u try to turn it on, the message display turns off and it shows nothing.
  7. #6
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,166
    It sounds to me like a data bus communication problem. You need to scan for codes with a scanner sophisticated enough to scan all the codes and not just ECM.
    Don't mess with Binky Bear!
  8. #7
    Carvone is offline Cadillac Owners Fanatic
    Automobile(s): 07 STS 1SG & 10 STS 1SG
    Nov 2008
    Florida
    54
    268
    I had an old Eldorado that used to do this exact same thing, ended up being bad grounds. They were all somewhat corroded, dirty, loose, etc. After cleaning and tightening the problem went away.
    Not saying that it is your problem but something to keep in mind.
  9. #8
    Automobile(s): STS
    May 2013
    30
    5
    Quote Originally Posted by dkozloski View Post
    Ok I will try to get it scanned at Firestone or dealership and see if anything comes up.
    Quote Originally Posted by Carvone View Post
    I was thinking that also. Car was in a bad front end collision and has a rebuilt title. does anyone know where the ground points are on this car?
  10. #9
    Automobile(s): STS
    May 2013
    30
    5
    Does anyone know where the ground points are?
  11. #10
    cdezey is offline Cadillac Owners Fanatic
    Sep 2010
    NY, NY
    102
    Check frame rail
    Rails
  12. #11
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    28
    26,325
    Unibody cars - no "frame rails".
  13. #12
    Sep 2010
    NY, NY
    102
    Ok maybe its called k frame, but whatever it exactly its called i think its on the left side.
  14. #13
    C&C's Avatar
    C&C
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,906
    Quote Originally Posted by crazyburr View Post
    Here are a couple pictures that show where they are on an '11 STS (but you can follow the negative (ground) cable and they should lead to the grounding points.
    First photo is chassis ground, second photo is engine ground (check for clean and tightness; easy/peasy).
  15. #14
    Automobile(s): STS
    May 2013
    30
    5
    Very helpful C&C. thanks alot.
    I took off chasis ground and sanded down around it and cleaned off bolt since it had some dirt on it. did this on saturday and car has been starting up.
    but just in case, where exactly is the engine ground? driver or passenger side? and is near the motor mounts?
  16. #15
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    crazyburr, Just below the battery and to the right. Danny
  17. Remove Advertisements
