stuck on ipod hookup
Results 1 to 9 of 9
Cadillac STS Forum - 2005 through 2012 Discussion, stuck on ipod hookup in Past Cadillac Vehicle Discussion; I bought the clarion cca-750-600 cable for ipod. it has the 30 pin connector and rca cables for audio/video that ...
    nikod7 is offline Cadillac Owners Member
    Automobile(s): 2011 sts
    Nov 2012
    43
    I bought the clarion cca-750-600 cable for ipod. it has the 30 pin connector and rca cables for audio/video that will connect to cig. charger with a usb. I only got music coming out of the ipod and not the car. 2011 STS. I must need the 3.5 cable, right? also when i press the aux. key on the nav it just shows a video soft key on the screen but no on/off audio like someone mentioned before.
    What's wrong here?
    thanks
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,028
    Re: stuck on ipod hookup
    You need to select that "Video" soft key, it should start playing the iPod at that point.
    Nov 2012
    43
    I did push that too, but nothing changed. do I need to get the 3.5 that plugs into ipod for headset use?
  5. #4
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,028
    Interesting, that cable you have should do the trick as it is the same thing that Apple sells.
    If all else fails just get a 3.5mm to RCA cable, that's what I use and it works pretty good, just have to use a separate cable to charge the iPod.
    Is there maybe a setting on the iPod itself to tell it to send the audio through the 30pin connector instead of the headphone jack?
  6. #5
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,940
    I seem to recall Apple installing a chip in their genuine cables that the unit had to verify was there and if it didn't (aftermarket cable) it would not work. Just one of the many reasons I sold my iPhone 3GS and went to Android.
  7. #6
    Nov 2012
    43
    I have a lexus that I use this ipod in regularly. I use a cord that has 2 headphone size plugs onegoes in the ipod and the other into the car. I then use the 30 pin plug to usb lighter to charge, and it works perfect.
  8. #7
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,028
    Yeah, your not using the 30pin for audio in your Lexus. The above poster may be right, it could be that the Clarion cable you have will only work with a Clarion HU when using the 30pin...Just get a 3.5mm to RCA and call it a day
  9. #8
    Nov 2012
    43
    ok, I'll pick one up
    thanks
  10. #9
    Nov 2012
    43
    Thanks to all for your help.
    I bought the 3.5/audio l&r cable and all is well and sounds great, I saved $26.00 in the process too.
  11. Remove Advertisements
