Wth!!!!!!! Driveshaft? Need help quick!!!
Results 1 to 10 of 10
Cadillac STS Forum - 2005 through 2012 Discussion, Wth!!!!!!! Driveshaft? Need help quick!!! in Past Cadillac Vehicle Discussion; How in the world does this propeller drive shaft come out? Ive unbolted all the bolts but it wont come ...
    silver02ta is offline Cadillac Owners Member
    Automobile(s): 2005 STS V8
    Nov 2011
    36
    47
    How in the world does this propeller drive shaft come out? Ive unbolted all the bolts but it wont come apart? I tried prying it apart but nothing...am I not puttn enough a$$ into it?
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    Re: Wth!!!!!!! Driveshaft? Need help quick!!!
    silver02ta, Do you mean the drive shaft to the rear diff. Only four bolts on each end. I have had mine out once, easy. Danny
    Nov 2011
    36
    47
    im trying to take out my trans....I just need it out of the way...I only unbolted the front section that bolts into the tailshaft
    Mar 2012
    columbus ohio
    382
    silver02ta, You must unbolt the other end at the diff. the drive shaft should drop down. Danny
    orange57's Avatar
    orange57 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS Northstar RWD
    Nov 2010
    Phoenix, AZ
    34
    511
    You may be able to just unbolt the carrier bearing mount, and that may be enough. But it would be better to remove the shaft completely. I don't think you want to bend that bearing too much. I removed it completely. Torque specs are in my thread.
    Nov 2011
    36
    47
    I removed the carrier bearing mount too and it still wont come apart from trans??
    orange57's Avatar
    Nov 2010
    Phoenix, AZ
    34
    511
    Get a bigger pry bar. If I remember correctly, there are metal spacer tubes in the rubber donuts that the bolts go thru. When torqued down they are pretty much press fit into the trans prop. Take some pics and post them and I can tell you if I see anything you missed.
    Nov 2011
    36
    47
    Finally got it.... ughh
    Mar 2012
    columbus ohio
    382
    silver02ta, How big a pry bar did you use. Danny
    Nov 2011
    36
    47
    I used a ball joint separator lol
  13. Remove Advertisements
