Results 1 to 6 of 6
Thread: MAF sensor needs replaced every 6-9 months?
    BSchultheis is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    May 2013
    3
    I have a 2005 sts that was in a bad wreck. After it was repaired about 3 years ago they could not figure out why the check engine light would not turn off. They did a smoke test for leaks, replaced the MAF sensor 3 times, replaced the head gasket and still the light stayed on. I have been driving it every day and the light is on but it runs fine. The only problem is about every 6-9 months it begins idling rough and pinging upon acceleration a mid speeds 35-45 mph. We have had the MAF Sensor replaced 4 times and it is doing it again. Any suggestions?
    Thanks,
    Budd
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    There was an issue with this and an updated ECM cal was release I believe. Ewill3rd spoke about it a long time ago.
    orange57's Avatar
    orange57 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS Northstar RWD
    Nov 2010
    Phoenix, AZ
    35
    511
    That sounds like an issue I had when a coil went bad on one of my old cars. That car had one main distributorless coil. Not sure if the coil on wire would do the same thing. Does it ever throw a misfire code?
  5. #4
    May 2013
    3
    Re: MAF sensor needs replaced every 6-9 months?
    1BadCadSTS- I searched for the post and could not find it.
    Orange57-I have not been told by the technician that there was a misfire code.
    Thanks,
    Buddy
  6. #5
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    OEM air filter?
  7. #6
    May 2013
    3
    2 have been OEM. 3 were after market
  • You may not post replies
