Results 1 to 10 of 10
Thread: Part #'s for headlight assembly gaskets?
    The_Punisher is offline Cadillac Owners Member
    Automobile(s): 05 STS
    Feb 2013
    32
    21
    Im looking for the gaskets that go inside the headlight access covers. After looking on a few oem sites I cant seem to find them, any help please?
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Not available. Must buy the whole door.
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    Re: Part #'s for headlight assembly gaskets?
    Unless yours are broken in two, what's wrong with using Gasket Sealer, I believe #2,
    the NON-Hardening kind,as you are NOT in there, every day or week !
    Or Silicone Seal.
    Happy Motoring.
  5. #4
    Feb 2013
    32
    21
    I could go that route I suppose...I had a sealing problem before and combined the gaskets with some sealant. I installed 10000k HID's and cant see shit with them. Installing 4300k hids bulbs instead. So ill try just sealant by itself and hope it seals! THanks guys.
  6. #5
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,959
    I sealed mine with the clear silicone windshield stuff. Had to go in and replace the peanut bulbs, and had no trouble getting in.
  7. #6
    sub613's Avatar
    Mar 2009
    704
    I meant in conjunction with the rubber gasket,
    NOT sure it would seal well without the rubber !
    Gaps are large.
    Happy Motoring.
  8. #7
    chazglenn3's Avatar
    Sep 2004
    Tacoma, WA
    54
    1,959
    Yes, I used the clear silicone in conjunction with the foam seal that had a tear in it.
  9. #8
    mckellyb is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS N*, 1SF, 144K mi.
    Apr 2011
    Fort Worth
    650
    I found one was put in wrong at the factory, the other wound up partially twisted when I put it back in...
    So I got to do it all...again.
    I used clear tub and tile caulk, and went so far as to seal the easy-to-access part of the inner panels' outer edge.
    I didn't want to take it apart a third time.
    Peanut bulbs are now LED, so I should be good for a decade.
  10. #9
    chazglenn3's Avatar
    Sep 2004
    Tacoma, WA
    54
    1,959
    I thought the same thing and the cheap Chinese LEDs went out in less than a year.
  11. #10
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    I got mine from superbright and ones flickering lasted 2 years.
  • You may not post replies
