Help Removing Key From FOB
Results 1 to 2 of 2
Cadillac STS Forum - 2005 through 2012 Discussion, Help Removing Key From FOB in Past Cadillac Vehicle Discussion; I'm having a heck of a time removing the key from a FOB. The screw is removed, but it won't ...
    97CadillacPimpin is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac STS 1SF 113k | '97 SLS (blown hg @154k - sold)
    Oct 2005
    Central IL
    34
    353
    I'm having a heck of a time removing the key from a FOB. The screw is removed, but it won't budge, I've tried pliers and bent it, and also tried torching it but it's not moving at all. Any tips?
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Help Removing Key From FOB
    I think the slot that the key fits into has a funky notch; it's hanging on that. I fabricated my new-style fob (like yours) for my 2006 and I think it's more than just a taper.
    I'd remove the ring and secure the casting in a vice with some padding. Use a big set of lineman pliers & wiggle/pull.
    I doubt you need the old key so if you break it, you could always drill it out if you had to. I'd recommend using a drill press with a vice.
    Alternatively, these pieces/parts aren't very expensive when they come up on eBay. Just find a bigger hammer.
