Acceleration Noise
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Cadillac STS Forum - 2005 through 2012 Discussion, Acceleration Noise in Past Cadillac Vehicle Discussion; Every time I am at a stop and try to accelerate fast I hear this sound as if the shifter ...
    LiquidTrader is offline Cadillac Owners Fanatic
    Dec 2011
    152
    Acceleration Noise
    Every time I am at a stop and try to accelerate fast I hear this sound as if the shifter is not in proper gear or something. I can feel it in the shifter too. Once I release the accelerator and don't press so fast it will go without issue. But if I press it. I hear it going clicking sound
    Any thoughts?
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Sounds like the tcase chain.
    Your description is rather vague though.
    Dec 2011
    152
    I hear this chugging sound. Whenever I press down to accelerate fast. And it will not go unless I release the pedal a bit for a slower acceleration.
    I just hear this repetitive sound as if the gear is not in gear all the way. And the sound I can feel in the shifter.
    I don't know how else to describe it
    RobM is offline Cadillac Owners Member
    Automobile(s): 2008 SRX
    Mar 2013
    Florida
    6
    Re: Acceleration Noise
    I'm searching the forum for information on acceleration noise as the 2008 SRX we purchased in March has a "growl" upon acceleration. It can't be heard until after the engine warms up and is louder upon hard acceleration. Goosing the engine at a stop in neuteral does not produce the noise. Had the dealer check the noise but they stated the noise they heard was normal for the V6. It only has 25,200 miles on it and is under the certified warranty until July, so I need info to take to the service department. Anbody have any ideas?
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    2008 SRX has little in common with the STS. Take it to a different dealer.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by EChas3
    Chassis is different but driveline is identical. Same motor same tranny same tcase same diffs.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by LiquidTrader View Post
    Any thoughts?
    Hello LiquidTrader,
    I am sorry you are experiencing an acceleration noise issue with your vehicle. If you would like to discuss your concerns, please private message me your contact information, VIN and current mileage. Thanks!
    Sincerely,
    Laura M.
    Dec 2011
    152
    Thank you
    I've been having nothing but issues since purchasing this vehicle.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Quote Originally Posted by 1BadCadSTS View Post
    I thought the the 2008 3.6 SRX shared similarities with the 2008 V6 STS, not engine or trans with prior STS. Sorry if I was wrong. The one I once drove as a loaner had the smaller V6.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    You are correct. I missed the fact the srx owner had the V6. STS got the di motor in 08 while the srx continued with the non di motor through the 1st gen body (2009).
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I was even further off-base. I drove a 2nd gen SRX with the smaller V6. It's attractive but the interior uses space poorly for its exterior size, seems underpowered and requires premium gas for all that. I couldn't believe it had much in common with an STS. It must have been a 2009 or 2010.
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    I've read that the srx sts and cts first and second generation all shared similar If not the same frame.
    Quote Originally Posted by B1n2fra
    Specifications of the 2008 Cadillac SRX Cadillac introduced its car-based SUV, the SRX, for the 2004 model-year. The Cadillac SRX is built on General Motors' Sigma platform, the same chassis that underpins the Cadillac CTS and STS sedans. The release of the SRX gave Cadillac its first mid-size sport utility offering in the company's history.
    Read more: Cadillac Specifications - How To Information | eHow.com http://www.ehow.com/cadillac-specifi...#ixzz2SVyvHluu
    Tearsuvscarlet's Avatar
    Tearsuvscarlet is offline Cadillac Owners Member
    Apr 2013
    25
    12
    The same thing happens in my '06 STS, V6. In both Drive and sport mode, only when taking off from the line at a dead stop, give it the full beans and you get a ga-ga-ga sound before forward movement. If I'm already cruising and I punch it, everything is good. I'm assuming it's not a REAL problem, since during normal operation and driving conditions there are no symptoms. Maybe it's just the transmission having a hard time trying to catch up to the engine at first, or the limited slip differential? It's a fancy sounding word that has slip in it, and the noise kind of makes me think of gears that are not catching properly, or slipping, but I've honestly no idea how that diff works, so I'm just trying to sound smart.
  16. #14
    Dec 2011
    152
    Quote Originally Posted by Tearsuvscarlet
    Exactly!
    I do think its an underlining issue. And a start of or is a real problem though.
  17. #15
    orange57's Avatar
    orange57 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS Northstar RWD
    Nov 2010
    Phoenix, AZ
    34
    511
    Check your motor mounts and your diff bushing. If you Google STS diff bushing replacement there is a good diy write up that a member here did.
  18. Remove Advertisements
