Nav/Radio Dropped Dead 06 STS
Results 1 to 6 of 6
Cadillac STS Forum - 2005 through 2012 Discussion, Nav/Radio Dropped Dead 06 STS in Past Cadillac Vehicle Discussion; I parked the car at the mall, went inside for 3 hours, returned to the car and no Nav/Radio. No ...
    Lifer's Avatar
    Lifer is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac Eldorado ETC
    Apr 2007
    Coppell, TX
    905
    I parked the car at the mall, went inside for 3 hours, returned to the car and no Nav/Radio. No matter what I pressed or touched it would not come on. So I tried a shut down and restart. Nothing. This went on for three days, so I grabbed the Owners Manual and checked for a fuse for the radio. There is one 10 amp fuse under the right passenger seat. There is nothing else on that circuit to check to see if it is also dead. So, I lifted the rear seat and through some searching, found the fuse block (under the carpet in front of the rear seat), removed the radio 10 amp fuse and it was fine. Hmmmmmm. So, I replaced it. It was probably out for three minutes. Got everything buttoned up and started the car. There it was, my Nav/Radio. Just way to many tech systems in these cars nowadays.
    So if I had a new ATS or XTS or other fime GM car that now uses the screen as the whole radio/Nav/clock/AC/ and so on and it failed... Better start walking.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,478
    Re: Nav/Radio Dropped Dead 06 STS
    most of us will just disconnect the battery quick and it resolves a lot of simple problems like that.
    with the top post battery that some of the STS's have with the quick release cables its really simple and only takes a few seconds and no tools at all.
    curtc's Avatar
    curtc is online now Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,028
    I have had my Nav/Radio go out on me a couple of times...Screen comes on but does not respond to any touch buttons or console buttons, no sound, no nothing...
    I have found that if I disconnect the positive battery terminal (like mentioned above) for about 5 minutes or so it fixes it...maybe I just need to pull the fuse, that would be a whole lot easier...If it happens again I'll just pull that fuse for a minute or 3.
  5. #4
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,478
    I've done the disco both cables, touch them together for a second and re-attach and issue resolved.
  6. #5
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    ^^^ Worst case, reset your express windows.
  7. #6
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,918
    My Nav did that once and (surprisingly) ejecting the map DVD (the only button that did anything) fixed it. Weird, but a relief at the time.
  8. Remove Advertisements
