07 STS4 Brakes
Results 1 to 6 of 6
Cadillac STS Forum - 2005 through 2012 Discussion, 07 STS4 Brakes in Past Cadillac Vehicle Discussion; 07 sts AWD with double piston fronts. Replacing all 4 rotors and 2 front wheel bearings. Can someone tell me ...
    1grand6's Avatar
    1grand6 is offline Cadillac Owners Member
    Automobile(s): 2007 STS4
    Apr 2013
    MI
    3
    Post07 STS4 Brakes
    07 sts AWD with double piston fronts. Replacing all 4 rotors and 2 front wheel bearings. Can someone tell me the size of the socket I need to pull the wheel bearings off? Also I went to pull the back rotors off and I think its the ABS that's holding it on. It feels springy when I pull on the rotor. Any suggestions? What to do and not to do? Thanks! Newbie Mike
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    1st off still 2 brake systems you could have jl9 and je5
    2nd that the ebrake holding the rotor on still
    1grand6's Avatar
    Apr 2013
    MI
    3
    Re: 07 STS4 Brakes
    I have je5 that's the double piston part... So if its the ebrake what should I do to release it so I don't break anything pulling the rotor off? Should I just keep wiggling the rotor or should I disconnect the whole mechanism and pull it off with the rotor???
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by 1grand6
    Both jl9 and je5 have dual piston. J56 is the brembo 4 pistons.
    Stick a flat blade in the veins of the rotor at the 3 and 9 positions and work it back and forth till it comes off.
    1grand6's Avatar
    Apr 2013
    MI
    3
    Re: 07 STS4 Brakes
    OK thanks. I went through the FAQ's and seen many said just muscle the rear ones off. It probably has a rig to get over. It's 30 degree's here today what a crappy day to do brakes and bearings. Still haven't found the size for the axle nut, guess I'll be making a trip to the auto parts store. I'm sure it's the same size as all GM's maybe 35mm. Decided to paint the calipers and went with the black slotted rotors so hopefully they won't rust. Thanks again
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: 07 STS4 Brakes
    The shoes of the parking brake add to the difficulty.
  9. Remove Advertisements
