Transmission skipping.
Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Cadillac STS Forum - 2005 through 2012 Discussion, Transmission skipping. in Past Cadillac Vehicle Discussion; Guy at the dealer said that there is a mechanism in the transmission that keeps it from skipping. Does that ...
    maiahsdad's Avatar
    maiahsdad is offline Cadillac Owners Fanatic
    Automobile(s): 05 STS AWD 1SG
    Apr 2009
    Fishers, Indiana, USA
    484
    Does that sound right?
    orange57's Avatar
    orange57 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS Northstar RWD
    Nov 2010
    Phoenix, AZ
    35
    511
    Re: Transmission skipping.
    still not sure what you mean by skipping...
    maiahsdad's Avatar
    Apr 2009
    484
    Quote Originally Posted by orange57
    Like that old feeling when a clutch slips on a manual transmission. I'm not sure I'm feeling something like that, but I've seen transmissions that lag between gears, and the harder you press on the accelerator, the more it will slip.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    It sounds like he's talking about a torque converter lock-up shift.
    Don't mess with Binky Bear!
    maiahsdad's Avatar
    Apr 2009
    484
    Quote Originally Posted by dkozloski
    Sounds like someone's rising the clutch between first and second gear.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    Do you mean riding the clutch?
    maiahsdad's Avatar
    Apr 2009
    484
    Yup.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    Your transmission is slipping between 1st and 2nd gear?
    maiahsdad's Avatar
    Apr 2009
    484
    That's what it seems like, although very little. It's like, when I'm driving, before the car slips into second gear, I can feel the rpm's raise just a little bit before it drops into second year. This might even be normal.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    It may need an updated TCM program. Cadillac released many programs trying to address different issues. Some correct harsh shifts; for those that prefer them silky smooth? What clutch wear can be expected?
    Others prefer quick, positive shifts, even if a bit intrusive. Next, define a curve to that spectrum based on throttle position. Finally, after the real world experience of buyer feedback and warranty service claims, adjust the programming to please the majority.
    It's worth a shot. If you're without a warranty, a transmission repair can be daunting.
    orange57's Avatar
    Nov 2010
    Phoenix, AZ
    35
    511
    Complete swap at my dealer was just under $3k. Trans costs Bout $2k new, but you can get them remaned for around $1500
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    By the way I have this same issue when going from 3 to 4th. I have a thread open about it in the v forum. It's been identified as "shift flare." There's one other guy who has it but from 1 to 2 I think. E chase 3's recommendation about the update is my first step.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    Keep in mind that the TCM adapts to your driving habits and learns as you go. A good start might be to do the old battery disconnect trick which will reset the adaption process to original. If it goes away you'll know it's learned behavior.
  16. #14
    Feb 2013
    Whitestone, NY
    28
    3,211
    Yes good point. That was the first thing that was recommended and I already did that and no dice. Problem still existed but that advice is right in line with what fellow v members advised.
    So maybe it's not the tcm thing after all. Might actually be a mechanical issue. Ill eventually get to the bottom of it. Fun part is it's intermittent so showing the problem to the service guys will be tons of fun. And they'll think they fixed it, drive it, won't get the flare, give it back, charge me and the next day it'll happen again. It's gonna be a fun one. Well the powertrain warranty is still in so I guess they won't charge me.
    Or they'll somehow relate it to my headlight and charge me because headlights aren't covered in the powertrain! That's a shout out to you rnkath08! I feel for you.
  17. #15
    maiahsdad's Avatar
    Apr 2009
    484
    Now it's starting to skip from 3 to 5 when not feeding it much. Sound like it'll jump from 3 to 5, then remember that it skipped 4 and go back and get it. But if I take off faster, it'll shift normal.
    And when I shift from D to R to back up, it takes about 3 seconds for it to get in gear.
  18. Remove Advertisements
