Transmission skipping. - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 35 of 35
Cadillac STS Forum - 2005 through 2012 Discussion, Transmission skipping. in Past Cadillac Vehicle Discussion; How cold is cold? Cars will make the trans stay in lower gear to force higher RPM to warm up ...
  1. #31
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,531
    How cold is cold?
    Cars will make the trans stay in lower gear to force higher RPM to warm up the engine faster.
  2. #32
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    Re: Transmission skipping.
    Maybe it's time to trade the car in while still running. Replacing the transmission & torque converter would be half the car value. Danny
  3. #33
    CadiTamer is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS 3.6 RWD
    Dec 2013
    22
    117
    Quote Originally Posted by maiahsdad View Post
    Just payed attention to my car today. Noticed that when it's really cold out, it will hang in gears MUCH longer than normal. When it finally changes, it doesn't snap or jerk. It's a normal, smooth shift. But the RPMs are higher because of staying in gear longer. Any reason for concern?
    This is perfectly normal. When the car is cold, it'll delay the shifts and not lock up the torque converter. It's an attempt to warm up the engine and transmission faster so your heater will work and gas gauge will drop slower
  5. #34
    maiahsdad's Avatar
    maiahsdad is offline Cadillac Owners Fanatic
    Automobile(s): 05 STS AWD 1SG
    Apr 2009
    Fishers, Indiana, USA
    484
    ECM flash, tranny flush, and repaired left motor mount that I snapped when I toasted the V8 Challenger (Dodge) last month, fixed my problem. Shifts perfectly. Hope it stays this way.
  6. #35
    fly187's Avatar
    fly187 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac STS4
    Jun 2012
    Dallas Texas
    38
    84
    I had a similar problem with my old ford explorer. Dealer wanted to rebuild the transmission, and felt that was to much for the problem. Did some research and ended up dropping the pan and switched two transmission control solenoids for the gear I was having the slippage. Put it back together and drove it. Well guess what. I slipped in another gear. Bought a new transmission solenoid and replaced bad one. And 4 years later transmission runs as good as it was new. Spent about 100 between the solenoid and fluid over 2500 to re build it.
  7. Remove Advertisements
