Transmission skipping. - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 35
Cadillac STS Forum - 2005 through 2012 Discussion, Transmission skipping. in Past Cadillac Vehicle Discussion; Any worn out mounts? I have the surging up hills but a lil gas it stops....
  1. #16
    Charles Warren's Avatar
    Charles Warren is offline Cadillac Owners Fanatic
    Automobile(s): 2008 sts-v black raven 2004 cts black raven
    Nov 2011
    Atlanta, Georgia, United State
    88
    459
    Re: Transmission skipping.
  2. #17
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Quote Originally Posted by maiahsdad View Post
    And when I shift from D to R to back up, it takes about 3 seconds for it to get in gear.
    If this gets worse this Winter, it's very bad news.
    Good luck.
  3. #18
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,055
    Quote Originally Posted by EChas3 View Post
    Good luck.
    What would that tell you? Shot diff?
  5. #19
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Classic sign of GM automatic transmission failure is increasing delays when shifting to reverse; especially when cold. The only solution I've ever heard is rebuild. These may be completely different.
    I think a member found a refurb 5-speed for $1,700. Maybe it's just a leak.
  6. #20
    maiahsdad's Avatar
    maiahsdad is offline Cadillac Owners Fanatic
    Automobile(s): 05 STS AWD 1SG
    Apr 2009
    Fishers, Indiana, USA
    484
    hope so.
  7. #21
    maiahsdad's Avatar
    Apr 2009
    484
    The mechanics shop did not indicate any kind of week. I told them to check all fluids, and they said not to worry about it. That's what worries me. But I don't see anything leaking in the garage be there. Question. What does the sD mean on the instrument panel when I shift the selector to the right? Does it introduce a different characteristic for the transmission?
  8. #22
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    In the manual it would tell you you've selected sport shift mode which does in fact delay shifting and make them more firmer. I suggest you take some time instead of the time used to post here and read the manual. Your car is exhibiting nothing wrong. It's performing as intended.
  9. #23
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Sorry if I came off brash it was not my intention. To clarify S signifies sport mode. During this PAS performance algorithm shifting is highened as well as transmission fluid pressure. This will result in delayed response shifts and higher shift points to keep the car higher in the rpm band for more instant response when you hit the gas. It's similar to putting a shift kit in your auto tranny.
  10. #24
    maiahsdad's Avatar
    Apr 2009
    484
    I just noticed this morning, that when driving up steep hills the transmission does not easily kick down to a lower gear to support the load. I have to press it pretty hard to get it to skip down to a lower gear. It gives me the feeling like it won't release the lock up easily. Also, I feel like it locks up to early.
  11. #25
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Go to the dealer an complain about chuggle. Dealer will reflash the TCM with a new cal. It helps a little bit.
  12. #26
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    I had a chuggle with my car. The caddy dealer reflashed the TCM. It only helped to reduce the money in my billfold by $129. bucks. Then the fix was new torque converter. Danny
  13. #27
    maiahsdad's Avatar
    Apr 2009
    484
    Quote Originally Posted by 1BadCadSTS
    just left there. The service manger didn't know what "Chuggle" is. She asked and no one knew. They say they will check.
    And when I take foot off gas at slower speeds, I feel a thump. Kinda like that feeling when a mount isn't secure.
  14. #28
    maiahsdad's Avatar
    Apr 2009
    484
    Just payed attention to my car today. Noticed that when it's really cold out, it will hang in gears MUCH longer than normal. When it finally changes, it doesn't snap or jerk. It's a normal, smooth shift. But the RPMs are higher because of staying in gear longer. Any reason for concern?
  15. #29
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    I don't think so. This has been the case for all cars I've driven.
  16. #30
    maiahsdad's Avatar
    Apr 2009
    484
    Quote Originally Posted by Guy.Seminerio
    but not me. I'm not sure why I wild ride in 1st gear up to 2600RPM before it slides into 2nd.
  17. Remove Advertisements
