mirrors
Results 1 to 3 of 3
Like Tree1Likes
  • 2 Post By curtc
Cadillac STS Forum - 2005 through 2012 Discussion, mirrors in Past Cadillac Vehicle Discussion; I'm new here, and have tried to find the answer but unable to do so. My problem deals with the ...
    lff
    lff is offline Cadillac Owners Member
    Automobile(s): 2005 sts
    Apr 2013
    1
    mirrors
    My problem deals with the outside mirrors. The driver side does not operate with the switch and the passenger side goes all the way down when you start the car. I've reset the driver settings and the exit setting and place the mirror selector switch in the neutral position and it does not change anything. Any suggestions? My car is a 2005 STS.
    Thanks
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,063
    Re: mirrors
    If the switch is in the neutral position you will not be able to control either one of the mirrors with the toggle switch, you must switch it from L to R to control either mirror. Also make sure and SAVE mirror position for Driver 1 or 2 depending on what FOB you use. The passenger side going all the way down sounds like the curb assist feature which should activate once reverse is selected, but again, the mirror selector has to be set to L or R for it to work, whichever mirror is selected will use the curb assist feature.
    sub613 and sub613 like this.
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,966
    Re: mirrors
    Sounds like you might need a new switch.
