96' sts
Results 1 to 3 of 3
Cadillac STS Forum - 2005 through 2012 Discussion, 96' sts in Past Cadillac Vehicle Discussion; 96 STS drove it til it was at 25% oil life left, took it too get an oil change, and ...
    wr3k3d is offline Cadillac Owners Member
    Apr 2013
    96' sts
    96 STS drove it til it was at 25% oil life left, took it too get an oil change, and as im in a store they call and say no oil registered on the dip stick so they didn't want the liability.. so i buy 5 quarts and put it in.... it had a rough idle before but was pretty much cleaned after a throttle body cleaning, now i brought up codes and it has a random misfire, 02 sensor, and the reason my traction control light is on..i forgot... but the misfire was before ran out of oil and pretty sure its cylinder 5, and im pretty sure it inst getting a spark from the plug because im pretty positive oil is in it... there was a little oil in cylinder 6 and 8, cleaned it and it never came back, if i change plugs will i be good? and 02 sensor? if u can help thank you.
    120,000 miles always been takin care of from previous owner as i can tell. no paint chips, few rips only in driver seat everything else flawless,bought at 115,000
    really love this car, lemme know if you can help!! much appreciated
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: 96' sts
    You'll find better advice on the Seville forum as this area is frequented by owners of the 2005 & up STS. Unfortunately, oil life monitors are not he same as oil level monitors.
    Good luck!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by wr3k3d
    That's a waste of oil, and money.
    Oil capacity is 7.5 quarts. The dipstick will be dry with ~5.5 quarts remaining, and that's about when the oil level warning will be triggered.
    Why 5 quarts? We're you checking the level as you poured it in, or did you just pour it all in?
    The only thing our onboard scanner can't do, is specify which cylinder/s is/are misfiring. Have a parts store scan the codes for you, and they can tell you.
    Oil in the plug wells is normal, and oil is an electrical insulator, so it won't cause a misfire.
    Possibly. Plugs and wires are due by 100K, using only the correct AC Delco plugs. Delco wires are recommended as well.
    The O2 sensor would not cause a misfire.
