Startup Issues
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Startup Issues in Past Cadillac Vehicle Discussion; About 90% of the time, when I start my car in the mornings before heading to work, it will run ...
    maiahsdad's Avatar
    maiahsdad is offline Cadillac Owners Fanatic
    Automobile(s): 05 STS AWD 1SG
    Apr 2009
    Fishers, Indiana, USA
    484
    Startup Issues
    About 90% of the time, when I start my car in the mornings before heading to work, it will run for a bout 15 seconds, and then shut down. When I restart it, I have to hold my foot on the gas because it's idling so rough that it won't continue to run. Then after about 15 seconds of that, it will smooth right out and run like butter. And will remain perfect until I shut it off for an extended amount of time.
    BaTu is offline Cadillac Owners Enthusiast
    Automobile(s): '05 STS4
    May 2008
    668
    Re: Startup Issues
    Take a look at the intake bolts, they often loosen and cause a lean condition (or you may have another vacuum leak elsewhere). Too Lean shows-up first during cold (extra rich) start & run conditions like you're describing...
    dkozloski and dkozloski like this.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Startup Issues
    If you get a Check Engine light, reading that would be the obvious first step. but if not, the loose bolts mentioned above often don't set a code.
    maiahsdad's Avatar
    Apr 2009
    484
    Quote Originally Posted by EChas3
    A local mechanics shop said that the car had nine codes. He said that some codes cause other codes. Something about air. He says now I need to go to a dealer.
    orange57's Avatar
    orange57 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS Northstar RWD
    Nov 2010
    Phoenix, AZ
    35
    511
    Re: Startup Issues
    If you have the Northstar, I second the recommendation to check the intake manifold bolts. Or, check the vacuum line that goes from the back of the intake manifold to the brake booster. I had mine come loose once, and the car idled terribly. Although in my case the tube had come off and was fixed once I put it back on.
    maiahsdad's Avatar
    Apr 2009
    484
    Quote Originally Posted by orange57
    I have the Northstar. After pulling the codes, it seems that nine triggered. But the technician indicated that sometimes some codes will trigger other codes.
    But there was indication of air problems. And they suggest I go to the dealer for that.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,063
    Why take it to the dealer just yet?
    What were the codes?
    orange57's Avatar
    Nov 2010
    Phoenix, AZ
    35
    511
    Quote Originally Posted by maiahsdad View Post
    Ok, but before you go check the intake bolts. It is very easy to do. There are 10 to 12 going around the manifold. If any are loose, tighten them and then remove the negative from the battery to try and clear the codes. As we have been saying, loose intake bolts can cause a lot of codes. And if the first shop that looked at it wasn't knowledgeable on the STS they could easily over look it. It just may save you a trip to the dealer and a few hundred dollars.
    maiahsdad's Avatar
    Apr 2009
    484
    Are these intake bolts easy to get to? I don't own any tools here in Indiana. I would need to go and purchase what I need. Does anyone have any diagrams to show me what to do, and what to torque the bolts at?
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Basic hand tools especially in 1/4 will prove beneficial.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,312
    Re: Startup Issues
    A 1/4" drive ratcheting torque wrench, a 6" extension, a universal joint socket that fits the bolts, and a combination wrench are all I needed. If you take off the oil filler and power steering caps and yank off the beauty cover it's all in front of you.
    Don't mess with Binky Bear!
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Startup Issues
    Be careful not to over tighten. The proper torque is very light. Somebody got it handy? 12 in/pds?
    orange57's Avatar
    Nov 2010
    Phoenix, AZ
    35
    511
    Re: Startup Issues
    89 in-lbs for the manifold bolts.
  16. #14
    maiahsdad's Avatar
    Apr 2009
    484
    So we're saying to torque the bolts to 89 pounds? Not sure what the "in" represents.
  17. #15
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,559
    Re: Startup Issues
    that would be 'inch pounds' as opposed to the normal foot pounds.
    I believe people refer to this as just a bit tighter than finger tight.
    Keep in mind that the intake is plastic and over tightening will be an issue.
  18. Remove Advertisements
