Page 1 of 4 1234 LastLast
Results 1 to 15 of 49
Thread: 2007 Cadillac STS V8 WORST RIDE QUALITY! Help!
    Karsntrux's Avatar
    Karsntrux is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac STS V8, 2003 Cadillac Deville DHS, 2002 STS
    Apr 2013
    Columbus, Ohio
    31
    11
    I'm in a jam here. I LOOVE my 2007 Cadillac STS V8 RWD, F55 Magenride, with Sport Suspension, I believe FE3. It's what I believe to be on of the rarer cars, 6 Lug Wheels and Hubs, which I've been told is from the CTS V, but mine are stock. Brembo Brakes front and rear. Not a V. All stock. EG Grille and Body Kit.
    I love this car, but this is the worst ride quality I've ever felt in my life. I'm a used car dealer and I drove every type of 05-07 STS they sell prior to buying this one. MagneRide and Standard. All of which rode acceptable to me. Some better than others. I purchased this one, cheap, assuming the suspension was bad. 3 Cadillac dealers later, 2 independent shops later, all I've been told is my suspension is perfectly fine. As I said I'm a car dealer, and I drive more than my fair share of vehicles. Never in my life have I been in a car that rides so poorly. Even at 10mph, it absorbs no impact. Every bump shakes the entire vehicle. I feel no difference between Touring and Perf. modes. No leaks. No error codes.
    My questions are as follows. Does anyone else feel the same way about their STS? Is there some mysterious issue that can go un detected to cause this? Am I just SOL? If this is "Just how it rides." Which I truly just do not believe. If that is so, is it possible or feasible, to convert this car to a softer suspension, say base FE1/FE2, but using a simulator computer and base STS suspension setup, magnetic or not.
    I love everything about this car, minus the ride quality. I don't mind spending the dough to do the swap properly, if it's possible. As I said, I purchased this car at a steal of a price, from a man that just needed the cash.
    Any help is greatly appreciated. Thank you!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    Re: 2007 Cadillac STS V8 WORST RIDE QUALITY! Help!
    You need to drive a 2002.5 - 2003 STS. They were the test mules for the GM/Ferrari MRC system and their ride is anything but a "Cadillac ride". Love it ...........
    You're a dealer - do you have a code scanner test set ??? Look for suspension codes - you should be able to vary suspension stiffness in your car - wish I could.
    Karsntrux's Avatar
    Apr 2013
    Columbus, Ohio
    31
    11
    I have to disagree, we just had a nice 2003 STS on the lot with MRC. I've had a few now to date. 180,000 miles to boot, and though it's not plush as a CVRSS car like my DHS, it's still a very comfortable ride. In all honesty, I would be exceptionally pleased with that type of ride quality LoL. I would be very pleased with just the base 05-07 STS suspension. Compared to the way this 2007 rides, a 2003 with MRC is truly a BOAT ride. LoL
  5. #4
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    I had a magride 03 STS before my 07 V. I much preferred the ride of the 03. The 07 is much more fun to drive however.
  6. #5
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    You have 180k on your sts?
    Sounds like blown struts to me.
    You have the performance handling package. Gave the car sts v brakes summer only tires and strut bar.
  7. #6
    Karsntrux's Avatar
    Apr 2013
    Columbus, Ohio
    31
    11
    No, I was talking about a 2003 sts I have on my lot with 180k. My 07 sts only has 70k. I just recently replaced the tires with a really soft compound, especially built for ride quality hoping that would help. I was hoping the struts were bad, but 5 different places have told me otherwise. The worst part is for that harsh of a ride the car doesn't handle exceptionally well. Always feels like it's skating over bumps, not stuck to the road as I've heard my suspension package should do.
  8. #7
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Where are you located?
    Check the sway bar links and control arm bushings are a common issue.
  9. #8
    Mr.electric is offline Cadillac Owners Member
    Automobile(s): 2004 Deville
    Mar 2013
    80
    Maybe it has the wrong springs. Is the ride height too high. I had a 4runner that felt like it had wheels made of stone. I pulled out the last two leaf springs from the aftermarket heavy duty rear springs and it was at least driveable. The magnetic suspension could certainly be at fault but that would probably set a code. As a dealership mechanic at Toyota I have seen some very obscure hard to pin down issues that don't throw codes. Things like swapped vacuum lines or swapped wires in a plug housing can cause wired issues. It may be painful but you might be better off throwing on 4 standard non magnetic struts and springs and leaving the suspension light blinking to regain ride quality or just sell it.
  10. #9
    Mar 2012
    columbus ohio
    382
    Karsntrux, What size tires, Brand of tires & air pressure. On a smooth road how is the ride, Any viberation .Once I had one tire on my truck repaired & rebalance, that wheel jumped like crazy. Taken to another shop and balance again. It was fine after that. Danny
  11. #10
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    If this car has the rare factory option (available only on 2007 Platinum and by special order on later cars) with the V brakes & hubs, it's the highest performance suspension available on any STS; MRC isn't available on the V. Sell it emphasizing the Performance angle over Luxury.
    I'd be really surprised if the MRC shocks were bad w/o leaking or setting an idiot light.
    If you're intent on blunting the handling and softening the ride, Danny has the solution. Replace the tires with higher profile and sofeter compounds and lower the pressures. On my AWD w' MRC, I sometimes run as low as 29 front & 28 back.
    Sorry you don't appreciate it. If Platinums had ACC, I'd have some interest.
  12. #11
    wake's Avatar
    Sep 2003
    Stafford, VA
    812
    Quote Originally Posted by Karsntrux View Post
    Hmmmm, someting is defainately wrong with the suspension if it feels like you describe.
    Surprisingly, I found dealerships don't seem to know much about the vehicles they service.
    I'm getting ready to rebuild the suspension on my Escalade because the ride is so bad. Two different GM dealerships, one Caddy and one Chevy dealership said nothing is wrong. I've driven a couple of Escalades and a Denali neither had the ride quality problems I have. I also found my steering box to have play in it and cured quite a bit of problems I had with it by making a slight adjustment to it.
    I just finished rebuilding the suspension on my 98 Olds Aurora. No shops found any issues with it but when I removed the front struts and set them aside with no weight sitting on them I saw the strut compress itself, I could pull and push the strut like a plunger, absolutely no resistance. I also found the control arms loose and the sway bar bushing cracked and compressed.
    I rebuilt the suspension on my previous SUV, an 02 Trailblazer. Nobody found anything wrong with the suspension but after I rebuilt it, it rode and handled like a brand new vehicle.
    If it's floating and feeling disconnected from the road then it sounds like struts to me.
  13. #12
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by Mr.electric
  14. #13
    chachd is offline Cadillac Owners Member
    Automobile(s): 2006 STS, 2006 SRX
    Jun 2011
    68
    15
    Quote Originally Posted by 1BadCadSTS View Post
    On his post it says Columbus, Ohio!!
  15. #14
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Can't see that on mobile
    I'm western pa if you wanna come take mine for a ride.
  16. #15
    Karsntrux's Avatar
    Apr 2013
    Columbus, Ohio
    31
    11
    Thank you all for the great replies. I'm running sumitomo tour plus lsw 2454518 not z rated. At 28 lbs/tire. If you look at my pic here the car sits much higher in the rear than most that I see. The car doesn't float at all actually. It doesn't bounce. It's super stiff and absorbs no shock whatsoever even the tiniest bumps send shock waves through the entire car. Even when I drive it hard and corner hard it doesn't handle very well. Any bump while cornering at speed sends the rear end sideways and triggers stability. It always feels like its skating on ice. I can drive my corvette 90 mph over a bump on 270 and its fine. I go over that same bump at 60 in the Sts and it sends me 4 inches above my seat. Car doesn't bounce but no impact is absorbed and it makes me fly out of my seat. It's very harsh. Thanks for all the info guys.
    To my knowledge, it's a lux perf, v8 rwd. Rpo f55 fe3, it has 4 struts, 4 shocks, tons of sway bars, brembo brakes, 18 inch 6 lug wheels. image.jpg
  • You may not post replies
