Help! Please - 2005 STS window problems
Results 1 to 6 of 6
Like Tree1Likes
  • 2 Post By RippyPartsDept
Cadillac STS Forum - 2005 through 2012 Discussion, Help! Please - 2005 STS window problems in Past Cadillac Vehicle Discussion; I have a 2005 sts. My windows will not work at all. They will not go up or down. I ...
    Rglock is offline Cadillac Owners Member
    Automobile(s): Sts
    Mar 2013
    34
    1
    I have a 2005 sts. My windows will not work at all. They will not go up or down. I bought a brand new master switch on the drivers side panel. It still didn't fix it. Does anyone know any other things that could be wrong. Thank you
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    Re: Help! Please
    fuse?
    EChas3 and EChas3 like this.
    C&C's Avatar
    C&C
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,961
    Re: Help! Please
    +1, Rippy:
    Fuse; just about always the best place to start looking.
    King Tom is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac Deville
    Apr 2008
    34
    Re: Help! Please
    Check fuses and then. Sounds like a motor if not fuses.
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,843
    Re: Help! Please
    Power for the window motors is supplied by a 30A self-resetting circuit breaker. It's possible that the C/B is bad. Can you open/close other windows with their respective switches? If so, the C/B won't be the problem. If not, the C/B is one of the top suspects.
    Sep 2007
    Wilmington, NC
    13,969
    Re: Help! Please
    i think those breakers have their part numbers stamped on them directly ... if you take it out and see the 8-digit GM number stamped into it then any dealer should be able to get you one
    if they're expensive i can save you some $$
  9. Remove Advertisements
