Back-up Camera Display
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Cadillac STS Forum - 2005 through 2012 Discussion, Back-up Camera Display in Past Cadillac Vehicle Discussion; This has probably been disucussed before but I haven't found the thread. Is there an easy way connect a back-up ...
    jgoble48's Avatar
    jgoble48 is offline Cadillac Owners Member
    Automobile(s): 2011 Cadillac STS
    Apr 2012
    Seattle, WA
    69
    10
    CoolBack-up Camera Display
    Is there an easy way connect a back-up camera to the nav system video input? I have the nav loc pick but I think the video screen still goes blank when I shift to reverse - also I usually only turn on the lock pick when I want to make a phone call. If anyone knows if a back-up camera system is possible on a 2011 STS please let me know....Thanks...
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Only a tomm modified lock pick will work in reverse.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Back-up Camera Display
    Actually, it's the old 2005-2007 Tomm mechanical switch modified Lockpick's that give you Aux display in reverse. I don't see how it would be worth it:
    1. Put car in R
    2. Engage Lockpick
    3. Press Aux hardkey
    4. Press the Video softkey
    5. See if you hit anything while futzing with with the Nav
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Have one of the kids jump out to see if there is anything behind you.
    targetSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cadillac STS AWD 1SG
    Mar 2011
    33
    387
    Quote Originally Posted by EChas3 View Post
    1. Put car in R
    2. Engage Lockpick
    +1 )))
    I have these also, but without software it's useless.
    I have backup camera at my license plate light not oem+lockpick.
    It works but driver force to push aux button+video button every time in R mode. STS navigation unit doesn't support rear camera (not aux video) and possibility to add it.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Not worth it.
    jgoble48's Avatar
    Apr 2012
    Seattle, WA
    69
    10
    Thanks for all the reponses. Sounds like I'll have to rely on the back up sensor beeps. Why Cadillac didn't step up and add a camera to the car in 2008 I'll never know.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    If you don't have intellibeam you can get a CTS mirror with back up camera and go that route.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,528
    Yup some other GM models did a display in the interior rearview mirror for the backup camera with the non-nav cars.
    I want to say I drove a Chevy Traverse that had one in it. So that might give you more options if you lack (or don't want to keep) intellibeam (but you may not have high beam functionality if you remove it, you would have to verify as there is a relay that has the high beam power run through it that is related to the intellibeam).
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,816
    Shouldn't be a problem with changing out the mirror. IntelliBeam works by communicating on the data bus. To test this for certainty, unplug the connector on the back of the mirror. I don't believe GM would engineer this in such a way that if the mirror lost power the high beams wouldn't work, but it's worth validating. There are a lot of GM vehicles that have the display in the mirror. It's fairly easy to do.
    I installed this in my Bonneville using a camera and module from a 2008 Buick Enclave and an OnStar/Display mirror from a 2010 GMC Sierra pick-up.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    On off button for intellibeam is on the mirror though. CTS just has Onstar controls.
    ddalder's Avatar
    Aug 2008
    Canada
    2,816
    There is a configuration setting in the Instrument Panel Module that can be disabled to the other modules in the vehicle don't think it's installed. Probably not necessary to actually turn if off though. There is a chance a DTC will be set indicating that there isn't the correct number of modules connected to the data bus. This won't turn on any lights though.
    Quote Originally Posted by 1BadCadSTS View Post
    Just make sure it's turned off before disconnecting the mirror. Even if it was left on, the decision to activate the high beams is made in the module attached to the mirror. If it's disconnected, it simply won't be able to send a data message to turn them on.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    I like my intelibeam though hahaha.
  16. #14
    ddalder's Avatar
    Aug 2008
    Canada
    2,816
    Me too. As much as I'd like a backup camera, I'm not prepared to sacrifice my IntelliBeam for it.
  17. #15
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Only once have I ever felt the need for a camera. I was at a mall, parked between minivans. Most uncommon!
  18. Remove Advertisements
