2011 STS Noise on start up?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Cadillac STS Forum - 2005 through 2012 Discussion, 2011 STS Noise on start up? in Past Cadillac Vehicle Discussion; I had the 08 CTS with the 3.6 DI engine and i know it was a bit noisy sometimes. The ...
    Ghost Deany is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 Escalade, 2005 CTS
    Nov 2007
    NJ
    32
    788
    I had the 08 CTS with the 3.6 DI engine and i know it was a bit noisy sometimes. The issue im hearing on my 2011 STS is on a cold start up, it sounds like a clicking noise in the engine for about 1 to 2 seconds, and then goes away. If i turn it off and start it again it doesnt make the noise, seems to only be on the first start. Normal?
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Re: 2011 STS Noise on start up?
    Ghost, I'm sorry to see you're experiencing a concern with your 2011 STS now! If you ever would like Customer Service to investigate your concerns further, we're always available via private message (although I realize you're seeking input from other owners).
    Best,
    Katie
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,044
    How is the oil level?
    Nov 2007
    NJ
    32
    788
    Quote Originally Posted by curtc View Post
    Completely Full. Im about to go change the oil myself just for the hell of it.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,044
    How cold out are we talking here?
    Nov 2007
    NJ
    32
    788
    35ish? Its def. only on the first cold startup. Today i left work at 2pm and it was about 50 out and it was less noticeable
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Ignore it.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,044
    I would guess it's just the VVT dealing with the low oil pressure combined with the thicker oil due to the colder temp. Probably nothing to worry about...
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    You might want to make sure your next oil change includes the correct oil filter.
    Oh yeah, use Mobil1 5W30.
    Stupid me. You have the V6. Use the recommended oil.
    Nov 2007
    NJ
    32
    788
    What filter does everyone use? The only one I was able to find for this and the CTS's etc. was the Fram CH8765s (not 100% sure on the numbers there) seems to be the only filter at the store.
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Fram filters are junk
    Last i studied up on it?
    http://www.purolatorautofilters.net/...tionGuide.aspx
    Purolator PL25274
    oldcaddybuyer's Avatar
    oldcaddybuyer is offline Cadillac Owners Fanatic
    Automobile(s): 2011 STS | 2013 ATS (03 STS, 96 FWB)
    Jun 2012
    Frederick, Maryland
    377
    Mine was loud this morning on start up. It was cold for GA (32). I've noticed a slight 'tick' that sounds cyclical. It doesn't completely go away though. I've been debating on taking it in for service to see if there is actually an issue. Still under factory warranty. I believe its more than just "normal DI noise"
    Nov 2007
    NJ
    32
    788
    Mine has kind of went away, we have had a few 50 degree days in a row. Only issue i seem to have now is my power steering is making a slight whining noise after the car gets warmed up and driven for a few minutes. It almost sounds like after cleaning a window with Windex, the squeak rub noise when rubbing the window dry. It only does it when i first start to turn the steering wheel and then goes away. Any ideas?
  16. #14
    calif phil is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS
    Jan 2013
    Kansas
    513
    That first start clicking noise is normal when cold and is nothing to worry about. I hope you are using Synthetic oil. Have you checked your power steering fluid. It only takes a little bit low on fluid to make a noise.
  17. #15
    Nov 2007
    NJ
    32
    788
    The fluid is a reddish brown. I sucked that fluid out, added new fluid, did the turn the wheel to each side and checked the fluid again and brown fluid came back into the resevoir. I removed and added fluid about 7 times and cant get all the brown fluid out completely as I ran out of new fluid. Im taking the car in tomorrow under warranty. I could of bought another 4 qts and tried to flush it all out myself but i dont want to buy it and waste the fluid and have that not be the issue.
  18. Remove Advertisements
