Page 1 of 3 123 LastLast
Results 1 to 15 of 44
Thread: 05 STS Remote start not working??
    Cadzilla8's Avatar
    Cadzilla8 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac STS Northstar V8
    Feb 2013
    NY
    247
    Trying to get remote start to work on my 05 sts the remote has a 1 on the back I know some said if its 3/4 it won't work. I hit lock twice and hold the start button on remote and orange front lights flash but no startup. Any help much appreciated. Also how can I make it beep when I lock the doors twice I like that feature
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Check engine light on?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Re: 05 STS Remote start not working??
    the presence of the CEL disables it.
    Do you have NAV?
    The remote start feature has to be enabled for each fob as well, I know how to do it with NAV, not sure if you don't have it.
    Have you tried fob #2 by chance?
  5. #4
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,287
    The designation of fobs as being #1 or #2 has nothing to do with the number on the fob. It refers to the order in which they were programmed. All fobs are the same electronically. Only the programming makes one fob different from another. If the fob was programmed 3rd or 4th in order it will not operate the remote start and the memory functions cannot be saved. Read your manual.
    Don't mess with Binky Bear!
  6. #5
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    The procedure you described was wrong. I'll assume you have the fob matched correctly as 1 or 2 and have the option turned on (even if you're w/o Nav).
    Press Lock. The lights should flash.
    Press & hold Start for a second. The car will start and parking lights will come on.
    If you have had any recent waning lights, remote start may be disabled.
    If you have Nav, set the driver greetings. If you don't see them as you start the car, your fob isn't matched as 1 or 2.
  7. #6
    Cadzilla8's Avatar
    Feb 2013
    NY
    247
    No NAV and no CEL I will look for my other remote and report back if I have any luck
    No NAV and no cel. Tried with my second remote with no luck either. After I hold the start button the parking lights flash and that's it not startup
    How would I know if I have remote start on or not without NAV ??
  8. #7
    fly187's Avatar
    fly187 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac STS4
    Jun 2012
    Dallas Texas
    38
    84
    not sure of the difference, but on my 06 STS without NAV. You must go to setup menu thru the radio. You should have 4 function keys (buttons) around radio display. One should say setup. click that, then I believe driver preference. There will be a list of things you can enable and disable on the car, including Remote Start. If you don't don't have the setup key around radio display, then someone has changed the home keys and that, I don't know how to adjust., other than disconecting battery and hoping it defaults back to factory settings.
  9. #8
    Cadzilla8's Avatar
    Feb 2013
    NY
    247
    Thanks fly!! Went into the setup menu and remote start was on so I turned it off and shut off car. Then turned car on and put it back on and now it works!! Woohoo also put the beep when you look doors on too. Thanks again for help
  10. #9
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,287
    Quote Originally Posted by EChas3 View Post
    On my '06 I push the lock button once and then the start button for a count of at least four to get it to remote start. If I push the start button for just a second or so after pushing the lock nothing happens and the car doesn't start.
  11. #10
    Cadzilla8's Avatar
    Feb 2013
    NY
    247
    Yeah I got it now it was something in the system I had to turn on. What are the buttons you push to turn it off I know on my yukon if you hold start and lock it shuts off
  12. #11
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,287
    Once the engine starts there is no way to stop it remotely.
  13. #12
    Cadzilla8's Avatar
    Feb 2013
    NY
    247
    Actually there is I just figured it out if you did the remote start hit and hold start and unlock
  14. #13
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,061
    My 06 shuts off with another push of the start button if started remotely.
    Also, mine seems to have a timer of approx. 10 or 12 minutes. Is that normal?
  15. #14
    Cadzilla8's Avatar
    Feb 2013
    NY
    247
    Yeah there is a 10 minute timer incase you leave it on
  16. #15
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    You can also extend the runtime once for another 10 minutes. There's a maximum total of 20 minutes but unless you let it shutdown after the first 10 minutes, you can only approach the maximum. (It doesn't add 10 minutes to the runtime, it just sets the run time back to 10 minutes.)
  • You may not post replies
