Results 1 to 6 of 6
Thread: Another "whats that noise" question with video
    Four Fins's Avatar
    Four Fins is offline Cadillac Owners Member
    Automobile(s): 61 Sedan, 06 STS
    Jul 2012
    35
    40
    So here's a video of the noise I keep hearing every time I step on the gas. First off, vehicle is a 06 STS v6. It usually only happens at about 2000 rpms and doesnt matter if its cold, warm, or hot. If I gently push on the pedal you can't hear it, it only wants to show up under stress (going up a hill, heavier acceleration). I've tried a tank of top tier fuel and I've also replaced the purge valve thinking that was it but no luck. It sounds like its coming from the back of the engine towards the top but can't tell for sure because it only happens while driving. I can't replicate the noise at a stop while in park, neutral or drive. Anybody?
    http://www.youtube.com/watch?v=cbaKQ...ature=youtu.be
    Oh, and in the video you can hear it kick in especially right around the 28-30 second mark. Sounds like a marble in a tin can.
    Four Fins's Avatar
    Jul 2012
    35
    40
    Re: Another "whats that noise" question with video
    I guess this doesnt sound familiar to anybody?
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,548
    Not 100% sure if its the same noise (hard to hear in the video) as I have.
    To me it sounds like heat shield around the exhaust near where the exhaust comes down by the ground for the first time.
    Not sure how to explain it better than that. When this happens can you open the window or maybe even the door to see if you can better locate it?
    Mine seems to want to make noise if i coast around 28-32mph then lightly accel (around 1800-2100rpm).
    (keep in mind i have v8 awd though and you have a v6 rwd?)
    No idea what bad timing chains sound like though so who knows you could be dealing with that.
  5. #4
    Four Fins's Avatar
    Jul 2012
    35
    40
    Yeah, I guess it could be a heat shield. It's harder to hear with the window open and yes its a v6 rwd. I would imagine that with the timing chains going bad you could hear it even before 2000 rpm but I could be wrong. It's just weird that I can cruise on the freeway going 60 and you wont hear it at all but once you step on it or even mid-throttle you can hear it. Or I could be going 25 and mid-throttle and its the same sound at the same rpm.
  6. #5
    Mar 2013
    So is it the timing chain going bad that creates the ticking sound?
  7. #6
    Four Fins's Avatar
    Jul 2012
    35
    40
    Thats the question I need the answer too. I hope its something else thats not as serious.
  • You may not post replies
