CTS springs on STS?
Results 1 to 7 of 7
Cadillac STS Forum - 2005 through 2012 Discussion, CTS springs on STS? in Past Cadillac Vehicle Discussion; Ive been trying to find a set of D3 lowering springs for my '11 STS but I guess that they ...
    asgds3p2 is offline Cadillac Owners Member
    Oct 2012
    7
    CTS springs on STS?
    Ive been trying to find a set of D3 lowering springs for my '11 STS but I guess that they have been discontinued. I was wondering if anybody knows if the D3 springs for a CTS will fit on an STS.
    I've been looking at the suspension on my '08 CTS and it looks very similar but I would rather not have to pull a strut off each car to see if they are interchangeable. Any info would be appreciated.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: CTS springs on STS?
    Doubtful. Very little (nothing?) else is the same.
    ral1960 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Perf-Plat, fr 11 STS, 04 DeV, 76 Eldo Con, 74 Fltwd
    Jan 2005
    NC
    436
    Quote Originally Posted by EChas3 View Post
    Not so fast. I remember reading in 2008 that they used the STS front suspension in the second generation CTS, in part because it was already set up for AWD.
    I'd like to take my suspension in the other direction--softer. The only specs I've found on line is a passing mention that the base CTS spring rates are 300 lb/in, which seems very stiff to me. I believe my Intrigue's front springs were 160 or 180, and that was a slightly lighter car.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,537
    Get the springs for the FE1 RPO code to go softer or FE4 to get the stiffer ride. (V springs are FE4)
    Jan 2005
    NC
    436
    According to the RPO Codes I got from Katie, I have the FE1, but the constant motion, esp. side-to-side, on our roads is wearing me out. The 3 older FE1 STSs I drove seemed much smoother and more stable, but I drove them in other towns. I was paying careful attention, too, because I knew it would be firmer than my DeVille. We have few potholes or patches, and the main roads I drive were resurfaced in ~2009, but the heat and trucks must have warped the asphalt.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Tires are the quickest way to alter spring rates & influence handling.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,263
    Experimenting with tire pressure is almost free and sometimes gives good results. Start with the numbers on the drivers door post.
    Don't mess with Binky Bear!
  10. Remove Advertisements
