Lowering Springs
Results 1 to 5 of 5
Cadillac STS Forum - 2005 through 2012 Discussion, Lowering Springs in Past Cadillac Vehicle Discussion; Has anybody with the air ride suspension installed lowering springs on their STS? If so what springs did you use? ...
    Marco05-STS is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    May 2011
    Houston, Tx
    29
    27
    Lowering Springs
    Has anybody with the air ride suspension installed lowering springs on their STS? If so what springs did you use? I contacted D3 they said the springs they offered are now discontinued. Thanks
    STS Serge 172 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac STS
    Mar 2011
    Washington
    27
    78
    Re: Lowering Springs
    D3 was the only company that I knew of that offered lowering springs for the STS V6. Not sure if there are anymore out there.
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    Buy regular used springs from a salvage yard and cut one or more coil out. Just a thought. Should work.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,494
    Quote Originally Posted by B1n2fra View Post
    Coil cutting can be very difficult to get right / done properly.
    It will also affect the spring rate of the coil more drastically than a properly made shorter coil, this typically means the ride gets more bouncy and less controlled.
    cadillacboy22's Avatar
    cadillacboy22 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac STS V6
    Jul 2011
    27
    60
    Would Sts-v springs work? I know I saw a company that still sells those other than D3.
  8. Remove Advertisements
