Euro/United Kingdom TPMS Reset Procedure
Results 1 to 7 of 7
Cadillac STS Forum - 2005 through 2012 Discussion, Euro/United Kingdom TPMS Reset Procedure in Past Cadillac Vehicle Discussion; TPMS Sorry Typo 2008 Model UK/Euro Spec 3.6 STS I have ordered a new wheel sensor, as my LH rear ...
    johndm is offline Cadillac Owners Fanatic
    Automobile(s): 2013 Camaro 2SS, Sold 2009 Euro Spec STS 3.6 Sports Luxury
    Mar 2010
    Bedford UK
    59
    108
    WinkEuro/United Kingdom TPMS Reset Procedure
    TPMS Sorry Typo
    I have ordered a new wheel sensor, as my LH rear is getting lazy in cold weather.
    I hope to use the relearn procedure as found on this forum as pasted below, but as my UK spec is Right Hand Drive
    will the instructions be reversed, ie learn in this order, RF LF. LR, RR, or as per USA model LF, RF, RR, LR
    The TPM matching process is outlined below:
    1. Set the parking brake.
    2. Press the push-button ignition switch to Acc.
    3. Using the keyless access transmitter, lock and
    unlock the vehicle’s doors.
    4. Press the lock and unlock buttons, at the same
    time, on the keyless access transmitter. A single
    horn chirp will sound, indicating that the TPMS
    is ready, and the sensor matching process
    can begin.
    5. Start with the driver side front tire.
    6. Remove the valve cap from the valve stem.
    Activate the TPMS sensor by increasing or
    decreasing the tire’s air pressure for five seconds,
    or until a horn chirp sounds. The horn chirp,
    which may take up to 30 seconds to sound,
    confirms that the sensor identification code has
    been matched to this tire position.
    7. Proceed to the passenger side front tire, and repeat
    the procedure in Step 6.
    8. Proceed to the passenger side rear tire, and repeat
    9. Proceed to the driver side rear tire, and repeat the
    10. After hearing the confirming single horn chirp for the
    driver side rear tire, a double horn chirp will sound to
    signal the tire matching mode is no longer active.
    11. Set all four tires to the recommended air pressure
    level as indicated on the tire and loading information
    label.
    12. Put the valve caps back on the valve stems.
    Answers appreciated
    Mar 2010
    Bedford UK
    59
    108
    Re: Euro/United Kingdom TPMS Reset Procedure
    No one else with a Euro/UK STS on here.....??
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    Quote Originally Posted by johndm View Post
    ...Euro yes, but not a UK/RHD...your car is/was the only Sigma-based RHD-export STS I've seen here in the forums...
    Mar 2010
    Bedford UK
    59
    108
    There are only around 20 late model STS's in the entire UK, and approx. 210 CTS's, so finding another UK RHD owner here was not really expected.
    Guess I'll try the USA sequence when my sensor arrives and see what happens.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I'm gonna get one of those tools to activate TPMS sensors & matching them to new positions.
    Mar 2010
    Bedford UK
    59
    108
    I have conformation from my Cadillac Dealer that the UK/Euro sequence is the same as the USA sequence starting Left Front then clockwise around the vehicle
    army_kid is offline Cadillac Owners Member
    Automobile(s): 2005 STS V8
    Feb 2013
    36
    I tried activating the TPMS and I get a double horn chirp and nothing happens after that. Is there a message that will show in the info center?
  10. Remove Advertisements
