front seat back panel
Results 1 to 9 of 9
Cadillac STS Forum - 2005 through 2012 Discussion, front seat back panel in Past Cadillac Vehicle Discussion; Does anyone know how to remove the map storage panel on the passenger front seat my leather alternative is seperating ...
    neverlateSTS is offline Cadillac Owners Member
    Automobile(s): 2007 STS4
    Feb 2012
    Florida
    43
    Does anyone know how to remove the map storage panel on the passenger front seat my leather alternative is seperating from the backing and needs to be reglued. thanks
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    Re: front seat back panel
    neverlateSTS, Mine was replaced under warrenty. A plastic clip was broken. I didn't see how it was removed. I did see when the service tech just pushed it in place. No screws. Danny
    curtc's Avatar
    curtc is online now Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,046
    Wish my extended warranty covered stuff like this...my driver seat has developed this issue as well. Same thing happened to my 2001 Seville.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    There's probably a tool to remove the clips. Maybe someone with the manual or know-how will surf by.
    aliskerov is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac STS
    Sep 2011
    27
    125
    I've had the same issue. To remove the panel, you must reach your fingers under the bottom of the panel; it's the rounded piece that's under the actual map storage panel. Once you feel the edge of that pane (you have to get your finders between that panel and the panel that prevents things from going under the seat)l, grip it with your fingers and pull it down (you should be in the back seat behind the seat). Once that piece pops off, move your fingers up behind the panel and pull towards you; this will release all the clips. At the top of that map storage panel there are two plastic levers that go behind the top of the seat, so dont try to pry the top of the panel off by pulling towards you. Instead, once you feel like all the clips are out, grab the panel from the sides and pull down. It should come out.
    I will warn you: gluing that vinyl can be disappointing. I drilled holes in the hard plastic backing behind the panel, pumped it full of contact cement, and then had the panels sitting for weeks with 25lb bags of led shot sitting on where the plastic came loose, letting all the extra glue come out and for the whole thing to dry. After a few day it separated again. I repeated the procedure and it's still loose in places. So dont expect an easy ride and dont try contact cement lol. If you do figure out a great adhesive please do so that others know what works. Good luck!
    Feb 2012
    Florida
    43
    Quote Originally Posted by aliskerov View Post
    Thanks for the info i also found a seat back for sale on ebay and it showed the back side with all the attach clip areas you are so right about the upper tabs glad i waited before i pulled on them. I have had good success with 3M spray adhesives as I had this same issue on my Corvette door panels. The reason you will experience seperation after gluing is usually caused by the shrinking of the LA material(leather alternative} I generaly clean the attach surface with wax and grease remover then I carefully heat the LA so the weight can be applied to keep it against the panel during cooling.only after i have it stretched and relatively close to the final shape will i spray adhesive to half or less of the repair and press it in place using a balled up towel to prevent creases and finger pressure lines. once this is complete it should stay in place just to be sure weight can be applied overnight.
    BrianNave is offline Cadillac Owners Member
    Oct 2015
    1
    I have the same problem and designed a part to replace the tip of tabs that break off that can be printed on your 3D printer. I can print you out a few for $20 or send you the file for you to print your own for free. BrianNave@Yahoo.com
    nwjones18 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS V8
    Feb 2013
    Georgia
    30
    202
    Yeah the panel just pulls off. Start from the bottom of it and work your way up. I broke one of the tabs too, but was able to jb weld it back on..
    KRSTS Guest
    Try GOOP. I use it for everything
  12. Remove Advertisements
